#61
Old 06-27-2021, 08:54 PM
1980 TA 1980 TA is offline
My parts are sitting in my shop. Waiting to get the block, heads and crank back from the machine shop. Maybe I can get everything assembled by the end of July????
  #62
Old 07-03-2021, 10:10 PM
gavin gavin is offline
If you go to u tube and look up LS lifters in Pontiac’s (lsx hunter) and retrofitting GM roller lifters ( craw daddy customs) you will get a good overview of the setup. If randy can do a reasonably priced kit including the correct length push rods it looks very practical.
  #63
Old 07-03-2021, 10:54 PM
rohrt rohrt is offline
Originally Posted by GoatZillaRacing View Post
After many months of waiting, we fired the other guys and bought the machinery to make the Custom Injuneered Hardware for our Roller Lifter Guide Plate System in house. All backorders will be filled and plenty of extras ready for The Pontiac Nationals and INJUN WARS.
https://pontiacspeedshop.com/valvetr...-plate-system/
What are the pictures showing? Are they what raise and lower the plate?
  #64
Old 07-04-2021, 07:18 AM
grivera's Avatar
grivera grivera is offline
This is an interesting system. At engine speed, is there ever any contact with the lifter guide plate and the lifter body?
Will Rivera
  #65
Old 07-04-2021, 07:23 AM
grivera's Avatar
see post 45 - the video links show what you're looking for
Will Rivera
  #66
Old 07-04-2021, 11:10 AM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
No contact. The lifters ride squarely on the cam lobes. The plate simply prevents the lifter from rotating when and if it bleeds down due to the engine not running for a while.
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
  #67
Old 07-04-2021, 02:03 PM
67Fbird's Avatar
67Fbird 67Fbird is offline
will it clear over a megabrace? and or be capable of functioning due to the the megabrace is at the top of the lifter bore already (IIRC). I guess if needed the megabrace could be machined .060 on the top side so as to allow a below flush height to the lifter bore tops.
  #68
Old 07-04-2021, 03:04 PM
If you use countersunk allen head bolts you should be fine. See attached
Randy Repp
  #69
Old 07-04-2021, 03:12 PM
67Fbird's Avatar
figured it would be very close per the 2 designs...just not sure how much lifter tops were above the lifter bores
  #70
Old 07-04-2021, 04:08 PM
Lee's Avatar
Lee Lee is offline
Or if somebody over-revs the motor, and the lifter leaves the lobe.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
  #71
Old 07-04-2021, 04:18 PM
67Fbird's Avatar
^^^ good ?
I guess one would need to verify overall lift of the lifter relative to the lock plate ...per the side clearance as it is per 45*. lifter clearance......alot of things going on here but it is all simple math
  #72
Old 07-05-2021, 09:24 AM
grivera's Avatar
Is this system only effective for a given range of lift using the Sealed power lifters on your website? SPL-2148P
Will Rivera
  #73
Old 07-05-2021, 10:27 AM
Jay S's Avatar
Jay S Jay S is offline
Follow his instructions from post 48.
One area you don't hear about with the drop in Hyd Roller Lifters is the lifter body going below the oil feed hole in the lifter bore. The measurement is 2.000 from the base circle of the roller cam to the top of the oil feed hole in the lifter bore. This measurement is based on a 1.080 base circle cam.
Using our big .400 lobe lift cams, the Gaterman 1012 lifters still have a little room to spare as pictured in the first two pictures. The Sealed Power HT2148 lifters will expose the oil hole and spurt oil when the cam is on the base circle.
Our .377 lobe lift cams have a 1.135 base circle and work fine with either lifter.
Test your setup prior to firing it up by installing the cam and just placing the lifters in the bores. Keep the valley pan off and use your oil priming tool to prelube the engine and you'll see if it's losing oil. Some oil seepage around the lifter body is to be expected but if it looks like the Clampet's striking oil on the Beverly Hillbillies, you're asking for a rod or main bearing failure.
The key is to use a Hyd Roller cam with a 1.135 base circle or larger on a HT2148 lifter. Let me be clear, it will run regardless but at continued high RPM it will pump the oil to the top and bearings are going to suffer.
For anyone who has built an engine with these lifters and a large hyd roller cam, IF you don't know your cams base circle dimension, call your cam manufacturer and find out.
The hobby can't afford any more Pontiac blocks being destroyed.
Pics on our page at facebook.com/pontiacspeedshop
  #74
Old 07-12-2021, 10:42 PM
We should have all the backorders shipped by tomorrow. Longer than we expected but now that it's all Injuneered, the next batch will be much quicker.
The delays gave me more time to think it through and we all ended up with a better product.
New series of instructional videos coming soon too!
I guess it's true that good things come to those who wait.
ID:	569643   Click image for larger version
Randy Repp
  #75
Old 07-13-2021, 07:36 AM
grivera's Avatar
Do you offer a combo deal plate + lifters?
Will Rivera
  #76
Old 07-13-2021, 08:57 PM
AIRLGPS is $129 Lifters are $199 for Standard USA Made Sealed Power, $239 for PREMIUM USA Made Sealed Power lifters with snap ring retainers.
Buy them together for $300 for Plate and Std lifters, $335 for Plate and Premium lifters.
I need to add the packages to the website so if you the package price just order it separately and I'll refund you the discount.
Thanks!
Randy Repp
  #77
Old 07-14-2021, 07:20 AM
grivera's Avatar
Awesome- thanks Randy!
Will Rivera
  #78
Old 07-14-2021, 10:29 AM
djustice's Avatar
djustice djustice is offline
With this plate-system we can maybe use the stock valleypan?
Murphy's law - "Anything that can go wrong will go wrong".
-469 ,Butler 310+ Eheads, Hurricane intake portmatched by butler, Butler roller 230/236 @0.50 112 LSA, Johnson lifters, pypes 2 1/2" exhaust, 3.42 yukon duragrip lsd, holley sniper efi, hyperfuel efi tank +++
  #79
Old 07-14-2021, 12:58 PM
grivera's Avatar
Can I purchase on line and pick up in Norwalk to avoid shipping charges?
Will Rivera
  #80
Old 07-14-2021, 06:47 PM
Yes you can just say Norwalk is your comments. I'll refund the shipping charges.
Randy Repp
