Do you have to pull motor or can you raise motor high enough to do it?
Thanks Greg |
I’ve always found that unless the cars been sitting for a good number of days without running that for the add time I have to wait for stuff to stop dripping to keep the motor in the car and to put the pan back on so oil does not drop on the new gasket that I would rather spend that time yanking the motor out!
I like working on it in far greater comfort on a engine stand, and then I am always positive I will have no leaks!
have to ...NO
you will need it reasonably high to get the pan back and under the flywheel. If you V notch the piece of 4x4 it will feel MUCH SAFER when jacking up the front of the motor via the pulleys/balancer or HOIST on front "hook loop"you only need a couple inches UP. |
How high do you need to lift the engine to get past flexplate/flywheel with the pan?
Everyone needs to remove a pan with the engine in the car at least once in their life. If you do it a second time you're a really slow learner...
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
| The Following 5 Users Say Thank You to lust4speed For This Useful Post: | ||
Amen!
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Someone on the forum probably knows the details but I believe you can rotate the crank to a certain position that moves the counterweights to the best position for oil pan removal.
Yes it's possible to do, no you don't want to live through this experience. As has been mentioned, it's much easier to reseal the pan on an engine stand, than trying to do it upside down in chassis, been there done it, and wouldn't do it again. Plus you have the luxury of taking a shower in motor oil while under the car, something to be avoided, unless you enjoy an experience like this. If it was a SBC, Olds, or Buick, (I've actually done the 3 other makes in chassis) it's probably easier in chassis, but Pontiac used such a massive oil pan, and the bottom of the engine design is massive on what hangs below the centerline of the engine block compared to the other GM engines it's infinitely much more difficult. Kent Moore actually made a tool to lift the Pontiac engine in chassis for removal of the oil pan, but I've seen that tool used in a dealership I worked at, and it's not any easier than lifting the engine and blocking it up. It surely didn't make the job any easier by using the specialized tool. Unless you're a masochist that loves pain, and difficulty, just pull the engine. |
Once due to a oil pan gasket leak/Nylon timing chain gear failure. The second time was a plugged oil pump screen. A shop had changed the timing gear set but did not get all of the nylon out of the pan because it was trapped on the inlet screen. Tom V.
My son had an s10 truck the oil pump relief valve failed. It required pulling the engine of course and had none of that. I cut the bottom of the oil pan off, swapped pump and welded back together. No leaks...BTW thanks again for the scoops.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
Lots and Lots of discussion on this subject on the forum.
Do a search. Most will tell you though that at the end of the day, removing the engine and trans will be quicker and less frustration. If there is a 1/4" of interference or 2" you still will not get the pan off and out unless you can really get the engine high. Borrow two Pontiac friends, and the 3 of you will have the engine out in a 1/3rd of the time. Tom V.
2nd gen F-body....you need about 3" of lift on the front of engine...= about 2" at motor mounts....nothing special. You need about 8-10 inch from ground to flywheel.
Yeah it suxs but when you gotta do ...what ya gotta do...with exactly what ya got.....thats what ya do! |
Pull you engine.
Tidy up the engine compartment while it is out. Touch up or repaint the engine. Make sure nothing else is leaking while engine is out. Make sure freeze plugs are fairly new, before re-installing engine. Replace if not. Make dern sure rear main seal is not leaking, or even slightly wet. Make sure motor mounts are in good condition. Make sure steering gear has NO leaks or seeps...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
I did it 1 time 45 years ago just lifting the engine. NEVER again.
You are welcome Bill. As you noticed the scoops are much nicer pieces vs the aftermarket
parts, IF their size fits your objectives. Tom V. In your case, removing the bottom of the pan to gain access was the right move for you and your son.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
