Before I would go for cheap rollers that can and do fail and dump shrapnel your motor, I would install new stamped steel factory types in a heart beat!
Just confirm that the slot is long enough for your amount of lift and then save up for Sharp’s or stainless steel rollers. The only time I have seen factory stamped steel rockers ware badly at there nose is when used valves have been shortened and left with a course finish, or when naturally the geometry is off by a good amount. Super stock racers use stamped ones with no issues with far more spring pressure then you will likely be running!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 09-09-2021 at 05:11 PM. |
| The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
Crower and Harland Sharp are the only 2 I'll use. Primarily Crower on all builds but if I'm forced to use aluminum Harland Sharp is all I'll consider.
| The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
