Old 09-09-2021, 02:46 PM
pontiacmark's Avatar
pontiacmark pontiacmark is offline
Default Crower 72827-16 aluminum rockers
I know the stainless rockers are high quality. How are the aluminum? From what I have seen, most just stick with stamped for low end builds or buy high quality Harland Sharps. How do these compare?
1970 GTO
Originally 400, M20, Atoll Blue, PS, PDB, A/C
Now has 461 stroke, Keisler RS600 5 speed.
Just a fun driver
Old 09-09-2021, 04:23 PM
Before I would go for cheap rollers that can and do fail and dump shrapnel your motor, I would install new stamped steel factory types in a heart beat!
Just confirm that the slot is long enough for your amount of lift and then save up for Sharp’s or stainless steel rollers.
The only time I have seen factory stamped steel rockers ware badly at there nose is when used valves have been shortened and left with a course finish, or when naturally the geometry is off by a good amount.
Super stock racers use stamped ones with no issues with far more spring pressure then you will likely be running!
Old 09-09-2021, 05:09 PM
Crower and Harland Sharp are the only 2 I'll use. Primarily Crower on all builds but if I'm forced to use aluminum Harland Sharp is all I'll consider.
https://youtu.be/XqEydRRRwqE
Old 09-10-2021, 02:17 AM
Will Will is offline
Everything else Crower makes is good quality, so I would ASSUME that their rockers are good, too. But, that's just an assumption...
The Following User Says Thank You to Will For This Useful Post:
Old 09-10-2021, 07:55 AM
PAUL K's Avatar
PAUL K PAUL K is offline
FWIW.... Crower has discontinued their Pontiac aluminum roller rocker arms.
Go fast, see Elvis!
Old 09-10-2021, 08:19 AM
They are on clearance on the Crower site.
1970 GTO
Just a fun driver
Old 09-10-2021, 09:54 AM
The Crower aluminum BBC are kind of bulky compared to their SS rockers.
