Old 12-28-2021, 09:38 PM
Rar_421 Rar_421 is offline
Default Thoughts on this cam?
With all cam core shortages,6 week delays etc I bought this Howard's cam,going into a 400,.030 icons with 4x4h heads which are being converted to 2.11 intakes,stock intake,Quadrajet,log manifolds according to butlers compression calculator I should be at 9-1 with a zero deck and having the heads decked to 98cc,I understand those calculators aren't 100% accurate but it should be in ball park
Intake Duration @ .050": 213
Exhaust Duration @ .050": 223
Advertised Intake Duration (@ .006"): 267
Advertised Exhaust Duration (@ .006"): 277
Intake Valve Lift with OE Rocker Ratio (1.50): .450"
Exhaust Valve Lift with OE Rocker Ratio (1.50): .450"
Intake Lobe Lift: .300"
Exhaust Lobe Lift: .300"
Old 12-29-2021, 12:56 AM
ponyakr's Avatar
ponyakr ponyakr is offline
Looks pretty good to me.
Looks similar to a small Voodoo.
https://www.lunatipower.com/voodoo-h...8-256-262.html
Should make lots of low & mid range power.
If that's where you want your power range, it should work OK, IMO.
But if you want max high rpm power & to "leave nothing on the table", that cam is too small, IMO.
The Following 2 Users Say Thank You to ponyakr For This Useful Post:
Old 12-29-2021, 01:39 AM
Just a April-oct daily driver,I forgot to add Hughes 2000 converter and 3 36 posi
Old 12-29-2021, 02:24 AM
Stan Weiss's Avatar
Less seat duration, just about the same 0.050" duration and more lift than the Pontiac 524886 cam.
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 12-29-2021, 09:01 AM
steve25 steve25 is online now
Have you CC’ed those heads yet?
If they are late 73 casting dates then they may have started life at 114 CCs, to then get to 98 CCs would call for milling them down .096” !!!
Old 12-29-2021, 10:39 AM
Default Need More Info
You left out lobe seperation and ICL.
Can't say yea or nay
Clay
Old 12-29-2021, 10:58 AM
The Voodoo cam linked above has less seat timing. And probably more .200" duration, the Howards cam on the intake is listed with 125 at .200"
The Howards cam is listed on page 5 here with a 112 LSA:
https://www.howardscams.com/sites/de...016_17_mid.pdf
Old information here:
Old 12-29-2021, 08:52 PM
Clay
112 LSA
108 ICL
Old 12-29-2021, 10:17 PM
Will Will is offline
That'll be a pretty mild cam. Similar to factory 068 @ .050". Strong lower-midrange power, done by 5000-5200 RPM.
The Following User Says Thank You to Will For This Useful Post:
