#321
Just did a VA install on 442, makes my 3rd.
On that cap where the hoses come thru the firewall, if you use a 2.5-3" bolt for the crossbar, it makes it much easier to install. Use the EZ Clip hose and ends, you will be glad you did later. I have a smoothie plate going in my 'bird, and am going to use a 4-port straight manifold. It will be where DSE usually does their's, look on the website under projects for ideas. I'm going to use non-AC kick panels and retain the fresh air doors. I used a VA hardline for my heater hose run along the bottom of firewall, and an AN -8 hose with ends. On the fender side, I looped the heater hose to leave some slack, and put the hot valve there. .
#323
Instead of RTV for the hose/fan cap, I used ribbon seal like used on windshields.
#324
DSE car 4 port AC manifold pic.
#325
I'm using a Greenlee punch for the holes to avoid damaging the bezel...same tool electricians use to punch holes in conduit boxes.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
| The Following User Says Thank You to Gator67 For This Useful Post: | ||
#326
I had the Dash redone at Just Dashes. The console is a reproduction. I'll install the metal bracket with rivets, so at a glance, it will look factory.
#327
Your posts and photos are extremely helpful, thank you!
I've spent a lot of time on the DSE website...amazing stuff! I thought long and hard about running my lines though a port on the firewall like that. It certainly looks more finished and professional. My reasoning for not using the port is probably flawed...mainly, I felt that there would be 8 additional spots where I could potentially develop a leak. I was also a little concerned about the tight bends in the interior lines off the manifold. Finally, I hadn't fully planned for what else is going to end up on the firewall, and I didn't want to create a problem for myself.
#328
The upholsterer did a good job mimicking the OEM door panels. It took him 29 hrs...which seems like a lot, but he did start from scratch. I used the Al Knoch reproduction for the lowers...the brackets had to be tweaked a little, but they fit nice, and happy to see the dye Randy had mixed matches the material really well. Now that I look at the photo, I think the mirror adjustment bezel is going the wrong way? I also can't recall whether the pull straps get screwed directly onto the doors or whether they are secured only with the metal reinforcement strap?
#329
I can't answer any of your questions but just want to say that those look great!
Greg Reid Palmetto, Georgia |
#330
I CAN answer it. Its facing forward, which is Not correct...
May not be an easy fix as you'll need 2 more holes as they are offset. That said; will not be seen .. looks great!
" Long may we DRIVE !" |
#331
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#332
So the pull strap gets screwed to the metal strip on the back, from the back side I recall. ( outer most holes on the strap ends) A through screw attaches it all ( bigger, inner hole on the metal ends of the straps) to the inner door frame through the moisture barrier.
#333
Thanks for the assists! Another question. Should the opening for the sun visor center support bracket face the front of the car or rearward? Forgot to check before we installed headliner, and don’t want to make a mistake because the small spike will tear it.
#334
This faces to the rear so a person in a front seat can swing the visor out easily and use to block sun from a side window.
#335
That’s what I thought originally, but most pics I find online show it going the other direction. 🤔
#336
I was mistaken..
#337
#338
In post 322, that center pic is the heater control valve config. The hose is very stiff, so I created a loop to prevent kinks, and to allow for any future trimming if the end gets boogered. That is a non-smoothie plate install, but will add a smoothie plate in the future. On my GTO, since the control valve is only 5/8" pass-thru, I took a section of aluminum tubing and jammed it in one end, an JB welded it in there. That prevented me from having to do a loop. The 'bird I'm doing a straight manifold, will use 90 degree EZ-Clip fittings, and have them go behind the inner wheelwell/fender. Will use the same type of hard line as the 442 & GTO, and route it into that area by where the fan motor was, and probably do a loop for future changes. VA makes lengths of aluminum AC tubing, that has an AC fitting on one side, and a bubble type flare on the other side. I cut the AC fitting off and flare it for a tube nut, which cleans up the hose from the back of the head. (can see end in pic on post 322). .
#339
Here's some pics of the GTO valve setup.
#340
The wiring on the GTO I ran thru the cowl/fresh air area.
On the 442, I used a leftover hole from the OE AC setup. On the 'bird, will see when the time comes how I'll run it, but probably with a new, small hole and grommet. EDIT: You can remove the terminals from the connector, and only have to drill a hole the size of the one wire. Then just put the connector on from the other side. .
