Old 01-12-2022, 02:15 PM
POS Racing POS Racing is offline
Default Maybe the nastiest 350 Pontiac?...for now
Just dynoed my 350P 2.0 build and cant wait to get it in the Ventura!
584.5hp/523tq on 93 octane
BUILD SPECS
,030 custom Autotec pistons
Eagle 6.625" H beam rods
Eagle 3.75" stroke cast crank
10.7 comp. Cranks 175lb
Custom solid roller cam
244/[email protected]"
.676/.670 lift
112LSA
KRE D-port heads bought bare as cast
Custom chamber and port work to maximize potential with the small 3.905 bores
2.055/1.625 valve also for best 3.905 bore power
Victor intake manifold with tapered spacer
(Fully ported Street Dominator produced a bit stronger curve below 5000 rpm but lower peak numbers...576hp/521tq)
950HP Holley carb
1 3/4 headers
Started this build with a goal of 575hp/525tq on pump gas and a 10 sec Ventura (NA) in street trim. 2 boxes checked! Cmon spring!
ID:	581754   Click image for larger version
ID:	581755   Click image for larger version
Home of the 350 Pontiac that KICKED FULPER'S ASS!
The Following 5 Users Say Thank You to POS Racing For This Useful Post:
Old 01-12-2022, 02:32 PM
Real real nice job!
That high level of torque is very much due to all that valve lift and the attendant amount of air mass it allows to pass through the intake tract and the average high level of port velocity that is made!
Air flow and velocity go hand in hand in at least a 50/50 ratio!
A whole bunch of folks on here would love to have there .060” over 428 making that much power!
Once again that’s a sweet motor !
Old 01-12-2022, 02:38 PM
Real real nice job!
Thank you! My dyno guy said it looked more like a torque line than a torque curve. LOL By my crude measuring methods the port is right around 295ft/sec. 301cfm@199cc
Old 01-12-2022, 02:39 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Great job! Nice build!
Go fast, see Elvis!
Old 01-12-2022, 02:44 PM
Sirrotica's Avatar
Excellent job, truly an impressive effort.
Maybe the price of boat anchors will be climbing now....LOL
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
The Following 4 Users Say Thank You to Sirrotica For This Useful Post:
Old 01-12-2022, 03:00 PM
wish they made an off the shelf heads like this. I bet there would be more 350P out there if they did.
"KRE D-port heads bought bare as cast
Custom chamber and port work to maximize potential with the small 3.905 bores"
2007 Grand Prix GXP 5.3L
The Following User Says Thank You to 74Grandville For This Useful Post:
Old 01-12-2022, 03:10 PM
I agree 100% I think the 350P should not be so overlooked. My first stab at one made 380hp/425tq with mildly ported iron heads and a flat tappet cam. The nice flat curve made for a 12.40 street driven Ventura. Making some head & cam upgrades and that one is going in my son's Ventura
The Following User Says Thank You to POS Racing For This Useful Post:
Old 01-12-2022, 03:16 PM
tininjun68's Avatar
tininjun68 tininjun68 is offline
Congrats on the build/achievement! Where's your local track for testing? I know here in NJ, Atco is usually the first to open in mid March for T&T if weather cooperates...best of luck with whichever track you test at!
Question: how much would you estimate you've got in this build?
You know me, "Safety Forst"
68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history.
69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s
68 Mustang FB-Green/Black (Bullitt)
Old 01-12-2022, 03:22 PM
Stan Weiss's Avatar
BUILD SPECS
.676/.670 lift
112LSA
950HP Holley carb
1 3/4 headers
Very nice build.
Can you post the dyno sheet for the fully ported street Dominator? Depending on gearing and convertor it is possible that that setup might run faster in the 1/4 mile.
Stan
Pontiac Pump Gas List
Old 01-12-2022, 03:27 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Impressive! You may have started something here.
Old 01-12-2022, 04:12 PM
Scott Stoneburg's Avatar
Impressive. I can't wait to see the in car results. Let us know
Old 01-12-2022, 04:22 PM
Mason Dixon will most likely will be its first outing. Finishing up the roll bar and doing some suspension upgrades before we drop it in.
6500ish in parts..plus machine work on the short block....build has taken 2 yrs so that figure would be higher now. Couldnt even guess how much time I have in the port work, cam design etc
Old 01-12-2022, 04:24 PM
I sure hope so. The little 350P has been pretty much kicked to the curb.
Old 01-12-2022, 04:26 PM
Will do. Hoping to be at Mason sometime in March
Old 01-12-2022, 04:27 PM
JSchmitz's Avatar
Very true
Old 01-12-2022, 04:48 PM
Which part of the whole Intake tract where you using for the minimum port area in your port speed calculations?
Old 01-12-2022, 04:52 PM
That was what I came up with for average port speed using formulas from PipeMax and SRH site. Min cross section was 2.26 at the pr pinch. I am sure the port speed was much higher there.
Old 01-12-2022, 04:53 PM
Nicely done. So much for the canard that you can’t make horsepower with less than a 4.000 cylinder bore.
Dr. Thomas Sowell
Old 01-12-2022, 05:01 PM
Very nice build.
Stan
Thank you!
Here are the best pulls for a ported T2, the ported HSD, and a reworked Pro Products crosswind. Really think the PP intake will be the best street intake? Wishing I had spent more time with the PP but we had 5 intakes and 4 carbs along to test. Knew it was gonna be a long day and honestly was chasing numbers. Sigh. My wife wants to take it back with some customized spacers and see if the smaller intakes can be made better. 24 pulls now....I think its time to put it in the car and tune there!
73 Ventura. 3450lbs. Th350. 3.90 gears and 28" tire
ID:	581761   Click image for larger version
ID:	581762   Click image for larger version
Old 01-12-2022, 05:08 PM
Thank you. All depends on what the chamber is designed for I believe. Above .400 lift the flow on these heads get really unstable on a 4.155 fixture but is smooth as can be on a notched 3.91 fixture.
Recently had a set of KRE CNC chamber heads here and it was completely opposite....lost 15cfm by. 500 and kept getting worse from there. Same with the E heads I originally started the build with.
