Time to play what will it make (im putting the thread in street section because it will see quite a bit of street use)
4.250 stroke 4.380 bore 11:1 pump gas Wide port e-heads ported by Butler touched up by SD flow [email protected] 2.250in 1.74ex (bought used). Used ported Victor (somewhat matches heads) 1150 carb setup for pump gas 269-276 .750 112l/s cam 2 1/8 headers. Hope to have it on dyno soon'ish |
750 Hp with similar torque numbers at least.
1967 Firechicken, 499", Edl heads, 262/[email protected]" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. [email protected] mph with a 1.45 60'. Still WAY under the rollbar rule. |
Hmmm. Seems most to all would have missed on that 350 the other day.
I venture a guess of 789 HP and 725 torque
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I'll go 738 HP and 760 torque.
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
865 if I fix the heads
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
If? You need to get on it, time is running out.
512 cubic engine. 810 hp 750 torque.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 3:90 gear. 28" slick. Best so far 9.95@135 mph. 1.39 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exhaust 950 Quickfuel. |
Five years later and now all of the sudden you are in a hurry. Funny!
I'll have them done before you can get pushrods! |
| The Following User Says Thank You to slowbird For This Useful Post: | ||
What size or Diameter push rod are you going with? Thanks
Biggest that'll fit. Won't know until we get everything bolted together. But absolute minimum will be 3/8 thick wall which due to supply chain issues are really hard to get right now.
904 HP @ 6500 rpm
810 hp
855 with a small splash of Q16.....lol
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
What do you mean by saying that the intake somewhat matches the heads?
I could deal with the interface at the flange being somewhat smaller since that is a straight run and it does not even take the area of a wide port to flow 370 cfm, but you for sure need a good amount of added port area from the point in the manifold where the runners turn hard and from that point on up to the intersect of the runner and plenum. I going to go with a what I think is a generous 770 hp , especially in light of only having 11 to 1 compression.
There is power to be had by deliberately mismatching the intake runners at the gasket flange on certain combinations.
Are you talking about having the bottom of the intake port a bit higher than the start of the heads so the air/fuel has a little ramp to jump off of.
No Sir
