I was wondering the same thing. After reading everything I could find, I ordered the Gaterman lifters and the Goatzilla plate. (just last week) I am hopeful the plate will work even if I have to make some modifications to it. If that doesn't work, plan B is to order the Ford spider and dog bones. But I am determined to use the LS style lifters in my 400 stroker build.
I will post my progress, but this is a slow build. I would also be interested in the success or failure of other attempts to use the plate or dog bones. Maybe someone has even found a better solution.
79 Trans Am 400 4 spd WS6 68 Firebird 400 Convertible 70 Pontiac GTO 2007 Pontiac Solstice |
How a low-priced, aftermarket OEM replacement lifter would be less problematic than a high-priced aftermarket retrofit lifter still doesn't compute.
Triple Black 1971 GTO |
Aftermarket parts are often bottom-feeder junk with little or no QA, and potentially designed by amateurs/hobbyists/enthusiasts, and then invisibly re-designed by the actual offshore manufacturer by using inferior steel, improper heat-treat, imprecise machining, etc. OEM parts may be imported from the same hell-hole, but they're studied, inspected, verified, statistically-analyzed. They're produced in sufficient quantity to get "volume pricing". There's exceptions. For example, GM built the Citation; and advertised how many millions of dollars went into the development and testing to assure a high-quality, dependable, economical vehicle. It was thoroughly engineered: Apparently, they spend one million dollars to design the car, and then spent four more million to carve all the quality and production costs back out of every single system. OTOH, Moog built a reputation on it's "Problem-Solver" line of parts that (used to) be a trustworthy upgrade from OEM--OEM with the mistakes and cost-cutting removed. Last edited by Schurkey; 02-01-2022 at 10:42 PM. |
