Old 03-04-2022, 09:51 PM
Scott Thelander's Avatar
Default is this a 69 reverse lockout
I have this labeled as 69 Firebird with a Muncie can anyone verify for me thank you
Old 03-04-2022, 11:39 PM
Sport69 Sport69 is offline
Looks like one to me. Can't read the tag, does it say for Firebird?
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 03-04-2022, 11:45 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Appears correct.. Planning to sell?
Old 03-05-2022, 12:33 AM
Tellyshavilli Tellyshavilli is online now
Try to look tomorrow
Old 03-05-2022, 03:47 PM
A Schab A Schab is offline
No. That’s for a Auto. The Muncie swivel only has two bolts that hold it to the sub frame.
Old 03-05-2022, 04:42 PM
Hmmmmm
Must be 69 Camaro then
I had several 69 hurst shifters at one time in history
68 firebird 2.
69 firebird 2or3
69 small block Camaro
69 bb Camaro hurst complete linkage w mount plate
I will look more on line tonite too
Thanks gents
T
Old 03-05-2022, 04:46 PM
unruhjonny's Avatar
if you can post the stamped (full or partial) numbers on those rods, I am sure someone can confirm it for you.
1970 Formula 400
Old 03-05-2022, 05:53 PM
no stamping anywhere or on anything
yes I am going thru some f body stuff getting ready to
Old 03-05-2022, 10:07 PM
The upper rod fits all Firebird and Camaro. The Muncie swivel is also shared with both cars.
Old 03-05-2022, 10:28 PM
https://forums.maxperformanceinc.com...d.php?t=702075
# 11 post
danm wish cammer was still around ,,,, his picture is exactly what I have .. exactly
Old 03-06-2022, 01:01 AM
Scott,send me your e-mail and I will send you a picture. I don’t know how to post one on here. You could post it here for others then.
Old 03-06-2022, 08:50 AM
comanchefirebird comanchefirebird is offline
Hi Scott,
The pictures you initially posted look correct for a 69 Firebird with manual trans.
I have 4 of them here, all have provisions for 3 bolt screws to attach to the subframe.
Steve
The Following User Says Thank You to comanchefirebird For This Useful Post:
Old 03-06-2022, 03:39 PM
Default Lockout id
Thanks to all that took time to post a message
To a small trivial item like this…
So
Here are a few more angles of my linkage,
My upper rod seems real straight less a soft bend
3.5” up from the adjuster some I have seen like the picture of my buddies has a bigger kink ,,,
My swivel is nearly flat looking down from the top long arm has a 1/4" offset to the frame side
I have seen a few with a good/bigger offset bend near the end for the linkage rods
Also looking from the side my swivel arms make a Y shape
Many I looked at have them at a 90 degree orientation making the rod holes farther apart
20” center to center. On long my long rod to the trans ... seems a saginaw would be shorter and 3 speed also
12.5 end to center on vertical column rod
What are yours??? When you have time
Scott
ID:	585524   Click image for larger version
ID:	585525   Click image for larger version
ID:	585526   Click image for larger version
ID:	585527   Click image for larger version
Last edited by Scott Thelander; 03-06-2022 at 04:04 PM. Reason: I hate sideways pictures straight on my phone but downloaded the spin .... whatever
Old 03-06-2022, 03:48 PM
Default ID
So
A friend sent this picture of his original from his 69 RAIV TA. Just to liven up the discussion
His has 2 bolts and looks like his upper has a bigger bend farther up
The swivel looks a bit diff its brackets are at a 90 degree not a Y like mine ,,,,
And looks like I may have my rods in the wrong holes ????
Old 03-06-2022, 06:48 PM
Hi Scott,
I tried to crawl under the cars but cant get a useful pic
Attached is a pic of the 69 Service manual
This pic agrees with the layout of the reverse lockout on my two 69 4 speed cars (RAIII with M21 and RAIII w/M20)
Hope that helps,
Steve
Old 03-06-2022, 08:09 PM
Default Update
Thank you for the picture !!
I Just returned from getting my manuals and took a couple pictures also here’s a couple pictures of the linkage in a different direction similar to the manual thank you Steve as you stated and as the book shows it’s a Y On the idler leveler and my idler lever has the same shape and kinks as in the manual picture also has three mounting bolts the vertical lever to the column has a slight kink about 3 inches up and then straight just like mine and the reverse back Drive linkage rod has the same wiggles also so I think we’re getting really close with any of those 69‘s come with a two bolt support assembly just curious or the vertical steering column rod with a little bit bigger band in the middle thank you kindly don’t need to be touched up too much but just curious
ID:	585581   Click image for larger version
ID:	585582   Click image for larger version
ID:	585583   Click image for larger version
ID:	585589   Click image for larger version
Old 03-07-2022, 10:21 AM
unruhjonny's Avatar
Scott;
Those two in the middle look like second gen Firebird three speed reverse rods.
https://forums.maxperformanceinc.com...9&d=1646612656
I had recently been sorting my own manual transmission shift linkage;
I was hoping to figure out if I had any correct second gen Firebird Muncie four speed linkage (which I do not).
1970 Formula 400
Old 03-23-2022, 03:07 PM
turbo69bird's Avatar
I’d be interested in knowing the build date on the cars . The 69RAIv w the two bolts and the 69 RAIII w the 3 bolts.
One of mine has 5290 on it and an S on the other side, this is not the bracket that bolts to the car (3 bolt by the way) but the part that swivels. Onto that piece .
960 HP @ 11 psi, 9.70 at 146.
Old 03-23-2022, 03:13 PM
The IV car is 08 E.
Old 03-23-2022, 09:39 PM
Believe mine is 03B
This pictured part is the part with the number and S on the back .
