Old 04-18-2022, 10:10 PM
joes455 joes455 is offline
Default Drum to disc rear brake
76 ta want to convert.Have moser axles with 10" ralley wheels lug eccentric.Looking for the brake shoes style e brake .Whats out there .all i have are the 80 trans am backing plates.Thanks joe
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 04-18-2022, 11:23 PM
We have a setup - requires 15" rims:
http://scarebird.com/index.php?route...product_id=178
Old 04-19-2022, 12:32 AM
chevymad chevymad is offline
I used trailblazer rears on my 74. Parking shoes in the hat and all. Somewhere on here is a guide to what you need.
Old 04-19-2022, 11:54 AM
Schurkey Schurkey is offline
Or hit the Treasure Yard, bolt on a pair of 11" drum assemblies, save a heap of money and eliminate a pile of headache.
Old 04-19-2022, 01:15 PM
Scarebird will the jimmy rotors fit 1/2 inch wheel studs?
Old 04-19-2022, 06:29 PM
yes, my T/A has 1/2" studs:
Old 04-19-2022, 06:48 PM
95-97 Lincoln Towncar has the mini-drum brake build into the Disc hub.
My GTO Dana60 did not do that. It has 79 T/A rear discs with 82-86 T/A calipers and brackets for old scool Emerge Brake apply. Geez been since 2006 and not needed any maintenance on the rear brakes.
Old 04-20-2022, 07:16 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
just completed my S-10 swap...from 1981 oem 4 wheel disc. I did have to add 1/4" spaces to the backing plate to get the 4x4 rotos to line up centered in the abutment bracket. Other than that (minor mod to the spacers as the flange face actually has a locating pilot on it measuring 2.830" so 1 each spacer had to be "opened up" in order to fit flush)
Old 04-20-2022, 02:35 PM
If you have some coin burning a hole in your pocket, Kore3 makes a kit to adapt C5 Corvette parts:
http://www.kore3.com/proddetail.php?prod=10277-01
I bought the calipers from a junkyard, and the rotors/pads separately. Kore3 makes great stuff, the e brake setup is gorgeous. Tobin(the owner?) is also very helpful, I had no problem getting ahold of him over the phone.
Old 04-20-2022, 08:29 PM
I think I'll stay with the oem design.I have the oem bracket and oem calipers ill use as core for new ones @ 50.00 bucks a piece comes with springs
Old 04-20-2022, 08:30 PM
ta man ta man is offline
Nice parts! Now I know where to direct guys looking for rear brake parts!
Old 04-21-2022, 12:00 AM
76TA462 76TA462 is offline
On my 76 TA I went to Wilwood for my disc conversion. Four piston calipers, 12.19” rotors. Part 140-7149DR. Had to pull the axles. And go larger than my 15 inch OEM wheels (Rally) but might not have had too. But happy I did for other reasons.
Old 04-21-2022, 12:18 AM
If you do that make sure to adjust/ratchet up the calipers E-brake first BEFORE bleeding. Also, every time you shut off the engine, engage the parking brake.
Old 04-21-2022, 11:26 AM
Scarebird your set up is starting to sound good.How much to 32025
Old 04-21-2022, 12:02 PM
They are $206 plus 22 shipping.
Note we are 3-5 weeks out like a lot of the industry.
