Old 06-16-2022, 07:24 PM
78MayanW87 78MayanW87 is offline
Default Help with rear end decode
Experts - I have attached a pic from the passenger side, forward facing axle tube rear end code stamp from my 1978 Trans Am. I am a little, no... a lot...confused. In trying to decode this, the coding convention doesn't seem to line up with the various references that I have looked up. If I just focus on the "PP" code, that would indicated that, for a '78, it is a 3.23 rear end. However, when I rotate the driveshaft and count the wheel revolutions, it measures out to roughly a 2.41. That could be off, but it is definitely not 3.23. Also, the "G" would seem to indicate (I think) that it is a GM axle housing rather than Pontiac. Maybe this is normal, but I would have expected a Pontiac code. I know that I can pull the rear cover and count ring and pinion teeth but before I did that I thought that I would reach out to the experts and see what you all thought... Fire away!
Name:	Rear End Code.jpg
Old 06-16-2022, 08:07 PM
scott70's Avatar
scott70 scott70 is offline
Is it posi?
Old 06-16-2022, 08:12 PM
Originally Posted by scott70 View Post
Is it posi?
Yes, it is a posi. I should have clarified that.
Old 06-16-2022, 08:32 PM
Type PP in this:
Axle Code Search
Old 06-16-2022, 08:36 PM
4PP G342 2
Old 06-16-2022, 09:09 PM
Click on the 'Axle Code Search' in my 1st post. It is a link.
Should have a input area. Type 4pp instead of the pp.
I think it is a 1979 3.23 axle.
Is your rear end a safety-track? (posi)
Old 06-16-2022, 09:16 PM
It is a posi, but like I mentioned in my initial post, there are only about 2-1/2” driveshaft rotations per wheel rotation. What am I missing?
Old 06-16-2022, 10:47 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Isn’t ‘78 an oddball year with 3.42’s instead of 77 or 79’s 3.23’s?
Are all the autos 2.41’s ?
Old 06-17-2022, 06:33 AM
phil400's Avatar
phil400 phil400 is offline
Don't now about all autos, but in 78 the 4speed w72s got 3.42 and auto got 3.23, for 79 both got 3.23 like in 77.
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs, 3rd and last owner since ‘99, as long as I'm alive.
79 Parisienne originally 305 2bbl now 87 350 tbi swap, 193 heads, performer, Q-jet, headers
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
The Following User Says Thank You to phil400 For This Useful Post:
Old 06-17-2022, 07:03 AM
The Champ's Avatar
It's very possible that someone changed the original 3.23 gears to whatever gear ratio is in the car prior to you purchasing the car. Assuming your rough calculations are correct, maybe a previous owner wanted a higher top speed or better fuel mileage/lower reving engine.
The Following User Says Thank You to The Champ For This Useful Post:
Old 06-17-2022, 07:26 AM
I'd agree with that.
Probably have to pop the cover off and count the teeth for actual ratio.
(and could probably tell if it is a GM gear)
Old 06-17-2022, 07:57 AM
phil400's Avatar
How does the car feel? I mean a car with 3.23 or 3.42 will have alot more gitty-up from a dead stop over 2.41, what rpm you running at 70? That's another easy general way to tell..if you're spinning at or around 3k @70 it's definitely not a 2.41, imho
77 t/a sold
83 Mustang GT sold
Old 06-17-2022, 08:45 AM
mgarblik mgarblik is offline
Honestly, why guess? 10 minutes and a $4.00 gasket and you have your answer for sure. Plus you can look at the teeth for condition, determine if the gear set is GM or aftermarket, you know for sure what you have. It's a 44 year old housing. May have had multiple gear changes by now. Let us know what you find.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 06-17-2022, 09:17 AM
My 78 180 HP TA TH350 had 2.56s.
Old 06-17-2022, 11:19 AM
Agreed. I initially was not able to see the axle code and so had just rotated the driveshaft and counted revolutions and came up with a rough 2.5 and so assumed that I had a 2.41 and was planning on changing that out to a lower gear. Yesterday I spent a little time cleaning up the axle housing and was able to read the code and was thrown off when I decoded as a 3.23 but non-Pontiac...hence the post. I will pull the cover off, count teeth and report back what I find. My guess is that someone, rather than changing out the ring and pinion as was suggested, replaced the entire rear end to achieve better fuel mileage. Although that runs counter to what I have found in the engine where they certainly weren't going after better fuel mileage. Who knows who, what or when any of this was done over the past 45 years! More to come and thanks to all for the input! Lee
Old 06-17-2022, 05:28 PM
Ok guys - I pulled the cover and it looks like it is a 2.56 rear end. The code on the pinion gear is: 3984823-16:41-GM (see pic). As a reminder, the axle housing code was: 4PP G342 2. So, since I cant seem to match up a "4PP" code with a 2.56 rear end, it would seem that the gears were just swapped out of the original housing. I'm asking..... Also, any insight into the origin of the ring and pinion and what it may have come out of? Looks like it is a super common gear set but I didn't know if the code would give away any answers. Thanks for the help!
Name:	78 TA Pinion 2.jpg
ID:	592940   Click image for larger version
Name:	78 TA Rear End.jpg
Old 06-17-2022, 05:58 PM
I'll look in my 78 shop manual tonight it had a page with codes.
Old 06-17-2022, 06:13 PM
What is the date code on the cowl tag?
Old 06-17-2022, 09:25 PM
If you take off the bearing caps and look next to the case bearings, you can tell if the gear set has been swapped or is OE to the housing. If there is a single cast iron shim on each side, it is OE. They spread the case and insert one shim per side OE. If there are multiple shims on each side, the case/gear set have been serviced/swapped at some time in it's life.
Old 06-18-2022, 08:58 AM
All of the 78 codes start with a "2" for all body series. For posis 2PS -2.41, 2PT-2.56, 2PW 3.08, 2PX 3.23, 2 PY 3.42
Third letter identifies manufacturer G=Chevrolet Then day built of the model year(342), then shift-2
