Experts - I have attached a pic from the passenger side, forward facing axle tube rear end code stamp from my 1978 Trans Am. I am a little, no... a lot...confused. In trying to decode this, the coding convention doesn't seem to line up with the various references that I have looked up. If I just focus on the "PP" code, that would indicated that, for a '78, it is a 3.23 rear end. However, when I rotate the driveshaft and count the wheel revolutions, it measures out to roughly a 2.41. That could be off, but it is definitely not 3.23. Also, the "G" would seem to indicate (I think) that it is a GM axle housing rather than Pontiac. Maybe this is normal, but I would have expected a Pontiac code. I know that I can pull the rear cover and count ring and pinion teeth but before I did that I thought that I would reach out to the experts and see what you all thought... Fire away!
Is it posi?
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
4PP G342 2
Click on the 'Axle Code Search' in my 1st post. It is a link.
Should have a input area. Type 4pp instead of the pp. I think it is a 1979 3.23 axle. Is your rear end a safety-track? (posi)
It is a posi, but like I mentioned in my initial post, there are only about 2-1/2 driveshaft rotations per wheel rotation. What am I missing?
Isnt 78 an oddball year with 3.42s instead of 77 or 79s 3.23s?
Are all the autos 2.41s ? |
Don't now about all autos, but in 78 the 4speed w72s got 3.42 and auto got 3.23, for 79 both got 3.23 like in 77.
78 T/A 4SPEED, Original paint, match #s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs, 3rd and last owner since 99, as long as I'm alive. 79 Parisienne originally 305 2bbl now 87 350 tbi swap, 193 heads, performer, Q-jet, headers 77 t/a sold 85 Monte Carlo SS sold 83 Mustang GT sold |
| The Following User Says Thank You to phil400 For This Useful Post: | ||
It's very possible that someone changed the original 3.23 gears to whatever gear ratio is in the car prior to you purchasing the car. Assuming your rough calculations are correct, maybe a previous owner wanted a higher top speed or better fuel mileage/lower reving engine.
| The Following User Says Thank You to The Champ For This Useful Post: | ||
I'd agree with that.
Probably have to pop the cover off and count the teeth for actual ratio. (and could probably tell if it is a GM gear)
| The Following User Says Thank You to johnta1 For This Useful Post: | ||
How does the car feel? I mean a car with 3.23 or 3.42 will have alot more gitty-up from a dead stop over 2.41, what rpm you running at 70? That's another easy general way to tell..if you're spinning at or around 3k @70 it's definitely not a 2.41, imho
Honestly, why guess? 10 minutes and a $4.00 gasket and you have your answer for sure. Plus you can look at the teeth for condition, determine if the gear set is GM or aftermarket, you know for sure what you have. It's a 44 year old housing. May have had multiple gear changes by now. Let us know what you find.
| The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
My 78 180 HP TA TH350 had 2.56s.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Ok guys - I pulled the cover and it looks like it is a 2.56 rear end. The code on the pinion gear is: 3984823-16:41-GM (see pic). As a reminder, the axle housing code was: 4PP G342 2. So, since I cant seem to match up a "4PP" code with a 2.56 rear end, it would seem that the gears were just swapped out of the original housing. I'm asking..... Also, any insight into the origin of the ring and pinion and what it may have come out of? Looks like it is a super common gear set but I didn't know if the code would give away any answers. Thanks for the help!
I'll look in my 78 shop manual tonight it had a page with codes.
| The Following User Says Thank You to Skip Fix For This Useful Post: | ||
What is the date code on the cowl tag?
If you take off the bearing caps and look next to the case bearings, you can tell if the gear set has been swapped or is OE to the housing. If there is a single cast iron shim on each side, it is OE. They spread the case and insert one shim per side OE. If there are multiple shims on each side, the case/gear set have been serviced/swapped at some time in it's life.
All of the 78 codes start with a "2" for all body series. For posis 2PS -2.41, 2PT-2.56, 2PW 3.08, 2PX 3.23, 2 PY 3.42
Third letter identifies manufacturer G=Chevrolet Then day built of the model year(342), then shift-2
