Wish I could answer that but it being said, What’s wrong with the brand of pushrods you have now? I’m sure you know, this is unlikely to blame on the pushrods.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
Well I’m getting 16 pushrods cause I don’t want to replace just two. Just wondering
If the pushrods simply came out, your rocker arms were misadjusted (loose) and turned or rocked enough to allow the pushrods to slip out. That ticking you heard may have been loose rockers. If the pushrods are bent, then you had mechanical interference at play. Valves may have bounced and kissed the piston top or your rocker ratio and pushrod pocket offset may have caused your retainer to hit the guides. Things like valve spring coil bind need to be rechecked and ruled out but typically, you will also have a broken valve spring from coil bind.
Triple Black 1971 GTO |
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
