Old 01-04-2021, 10:23 AM
feral cat feral cat is offline
Default #13 cylinder head
date A160 casting only, cleaned, inspected $250 or bo loc ne pa
Old 12-14-2022, 08:12 PM
Default cylinder heads
also have prs of # 13, #46, #62, #670 available
Old 12-22-2022, 11:26 AM
61DragCat! 61DragCat! is offline
Do you still have the A160 #13 head for sale?
Old 12-23-2022, 09:48 AM
bradleyc309 bradleyc309 is offline
Would it be worth it or can you install #13 heads on a 1964 389 engine with Tri-Power?
Old 12-23-2022, 07:18 PM
The 64 intake will not fit on #13 heads. And I believe the valve reliefs in the pistons are not correct for the#13 heads.
Old 12-27-2022, 09:21 AM
I forgot to mention the Tri-Power Intake and Carb is 1965 model year.
Old 12-27-2022, 04:07 PM
This is a question that should be asked in one of the tech forums, I would suggest you try the Pontiac Street forum. This thread is in the classified forums and should not be used for technical discussions, out of respect for the seller who placed his ad here.
Old 12-27-2022, 04:13 PM
Old 12-27-2022, 06:39 PM
The 65 manifold will bolt to the #13 heads, but the 1964 piston valve reliefs will be wrong for the #13 heads. Are the engine block & the pistons 1964?
Old 12-28-2022, 08:55 AM
The block is a virgin 11H code engine.
