Old 02-10-2023, 03:13 PM
bsblguy bsblguy is offline
those are all a pillar channel. I need the part that goes all the way around and is between the roof frame and the roof skin. thanks for the help though.
Old 02-23-2023, 09:58 AM
Home made weatherstrip channel in place and starting to weld the new roof skin in place. I bought a 240v spot welder and it is working pretty well.
The Following 2 Users Say Thank You to bsblguy For This Useful Post:
Old 11-25-2023, 12:04 AM
Firemedic833 Firemedic833 is offline
I have the same problem you didn’t happen to make a video or take pictures of you making it did you?
Old 11-25-2023, 10:51 AM
I just used a piece of sheet metal and bent it to the shape I needed. The corners I had to cut the width so it would bend. I used a piece of extra exhaust pipe that I cut and bent to the shape I needed for the corners and bolted it to a table. The corners were the hardest part.
The Following User Says Thank You to bsblguy For This Useful Post:
Old 11-25-2023, 04:08 PM
Old 12-21-2023, 12:48 PM
You may want to try this place, they do stuff that's not listed too:
https://www.rustreplace.com/home/196...-1981-firebird
They make general 'stock' sections too. You might be able to use the trunk gutter stuff for what you need, or use it to start modding.
You might be able to chop up something from other models too:
https://www.opgi.com/sheet-metal-bod...yABEgKKVvD_BwE
Old 12-21-2023, 12:55 PM
https://www.ebay.com/itm/29608193226...Bk9SR8qB5tSRYw
