| The Body Shop TECH General questions that don't fit in any other forum |
This is the weatherstrip channel that goes between the roof frame and the roof skin then is spot welded together. I have had no luck with sheet metal shops so I tried restoration shops. They said anywhere from several months to a year before they could make it. I bought some sheet metal and am making my own. |
I remember seeing that on a bare shell of a (1980?) t-top body I was using to rebuild my first 1977. Some of the spot welds had broken away and I had trouble getting a 110v spot welder to melt all 3 pieces of metal back together.
Mike
Home made weatherstrip channel in place and starting to weld the new roof skin in place. I bought a 240v spot welder and it is working pretty well.
| The Following 2 Users Say Thank You to bsblguy For This Useful Post: | ||
I have the same problem you didn’t happen to make a video or take pictures of you making it did you?
I just used a piece of sheet metal and bent it to the shape I needed. The corners I had to cut the width so it would bend. I used a piece of extra exhaust pipe that I cut and bent to the shape I needed for the corners and bolted it to a table. The corners were the hardest part.
| The Following User Says Thank You to bsblguy For This Useful Post: | ||
FIremedic, I just saw this as its an old thread, but I may have these pieces. I will check later today. Not sure if you can pm or not but do so if you can.
You may want to try this place, they do stuff that's not listed too:
https://www.rustreplace.com/home/196...-1981-firebird They make general 'stock' sections too. You might be able to use the trunk gutter stuff for what you need, or use it to start modding. You might be able to chop up something from other models too: https://www.opgi.com/sheet-metal-bod...yABEgKKVvD_BwE .
