Old 02-12-2023, 11:12 AM
kpbrown31 kpbrown31 is offline
Default Buffing windshield?
My recent purchase has been sitting outside for 25 years and the windshield has some grime or hard water spots on the outside. If you wipe it down wet it will be clear until it dries.
Recently tried this buffing compound on a spot. It did clear it up some but now it has a dull haze when looking through it. Maybe I overdid it? The picture is before buffing.
I thought it might be between the layers of glass but it’s super clear when I wipe the outside down which gives me hope. Tried a little steel wool and various types of glass cleaner as well. Any suggestions?
ID:	607081   Click image for larger version
Old 02-12-2023, 11:22 AM
Tim john Tim john is offline
Cerium Oxide is used for polishing glass. I purchased it in the past from Eastwood but there are multiple sources available online
Tim john---
The Following User Says Thank You to Tim john For This Useful Post:
Old 02-12-2023, 03:50 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
If it’s just grime and hard water, this is the best I know of that 100% won’t do any damage yet still give a perfect finish. Sprinkle it on a wet windshield and buff away.
BON AMI 1886 Formula - 12 oz (Pack of 2) https://a.co/d/i7wuure
The original formula has no abrasives. Ace Hardware usually has it for under $2/can or can order it. If you’re actually buffing out scratches you need something stronger.
The Following User Says Thank You to Entropy11 For This Useful Post:
Old 02-12-2023, 08:05 PM
400 4spd.'s Avatar
Tim john---
That’s what I have used. It can also remove very fine scratches. Have patience and work it slowly.
Old 02-12-2023, 11:48 PM
RamAirBirds RamAirBirds is offline
Local "Detail Garage" here said to use a clay bar. My son did so on side glass for his 65 tempest which had the road haze. Came out great. used the clay bar lubricant as well.
The Following User Says Thank You to RamAirBirds For This Useful Post:
Old 02-13-2023, 09:46 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
I usually hit glass with Rubbing Compound when I'm buffing a car and it makes a noticeable difference in clarity. Do you have any of that laying around to see if it does a better job in conjuction with the glass polish?
Mike
Old 02-13-2023, 10:53 AM
Thanks for the replies guys. I did see cerium oxide when I first searching for the glass polish. I’ll have to give it and the clay bar a try. Hopefully I can report back with some good results!
Old 02-13-2023, 02:19 PM
Formulabruce's Avatar
Clay bar is good trick after polish dries. Toss it after, don't re use it.
Some of this on windows is actually mold..
" Long may we DRIVE !"
Old 02-13-2023, 10:10 PM
That mold you’re seeing is on the dash. Car saw some moisture leaking around the windows for years before I got it.
Old 02-14-2023, 12:02 PM
webfoot's Avatar
webfoot webfoot is offline
I've used CLR (calcium lime rust) in a spray bottle and some fine steel wool. The "hard water" spots are usually calcium carbonate. We have BAD hard water around here.
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
