Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-05-2023, 10:12 AM
Hawkgto Hawkgto is offline
Default 12 bolt Moser,428 Short block, round Port headers
Moser 12 bolt rear end a body Moser 33 spline axles, true trac posi diff, motive 3.73 gears, aluminum Moser diff cover, 1/2 inch studs, built by Moser, $3000.
Round Port headers 68-72 GTO, 70-81 f body $400.
Bop turbo 400 manual valve body great trans was in my car several years running 10.50s just pulled $1000.
10" Coan converter 3800 stall. $600.
428 Short block, bored over 0.30 new needs assembled new king bearings, total seal Rings, Forged pistons, eagle rods, Arma steel Crank all balanced, new balancer, gasket set, new cam bearings. Double roller timing chain , comp cam , $4000.
419-230-6681
Old 02-05-2023, 10:38 AM
78w72 78w72 is offline
what brand/part# are the headers? got any pics? location?
Old 02-05-2023, 01:35 PM
No name on headers.
Built-in the early 70s
I'm in Ohio
Old 02-05-2023, 02:20 PM
some pics of the headers would help to see the condition or for others determine what they are.
Old 02-05-2023, 03:39 PM
Text me at 419-230-6681
Could not download pictures
Old 02-05-2023, 09:46 PM
Try uploading a couple Headers photos Here: hit the button below " Go advanced " will pull from your photolist, easy.
Old 02-06-2023, 10:44 PM
428 is 4 bolt main ,new ARP studs
Old 02-07-2023, 07:58 PM
Adecco Adecco is offline
In regards to the 428 build specs on the cam and is all the machine work done
Old 02-07-2023, 09:04 PM
428 All machine work is done.
Needs assembled. Still at machine shop should be done soon.
Comp cam hydraulic flat tappet.
Xe284H-10
Int. Ex.
Lift 507-510
Dur 284-296
Old 02-07-2023, 10:43 PM
AG's Avatar
AG AG is offline
Is the converter the 20230 or the 20235?
Old 02-08-2023, 11:04 AM
Coan converter
coa-20320-2
New cost $1075.
Old 02-08-2023, 11:45 AM
AG's Avatar
AG AG is offline
Can you take a pic of the PN?
Old 02-09-2023, 09:07 PM
Pictures of converter part numbers.
The previous part numbers I posted are the part numbers that Coan supplied me a few days ago when I called them about this converter.
ID:	606963   Click image for larger version
ID:	606964   Click image for larger version
ID:	606965   Click image for larger version
Old 02-19-2023, 05:28 PM
428 Short block is sold
Old 02-20-2023, 12:14 PM
SHAWN MILLER's Avatar
SHAWN MILLER SHAWN MILLER is offline
Hi, Do you have the measurements for the rear, outside flange to flange if possible? Where are you located in Ohio? Thanks, Shawn
67 GTO 455,Super T-10,Wenzler Ram
79 Trans Am 455 Pro Stick Racing
2005 Thunder Mountain Blackhawk 103"
2019 Street Glide 114"
Old 02-20-2023, 02:57 PM
It's factory width.
I have it in my 70 GTO.
Near Lima Ohio
Old 02-21-2023, 12:44 PM
racegto65's Avatar
racegto65 racegto65 is offline
Is the converter standard space or for a mid plate.
Old 02-21-2023, 12:50 PM
Standard
Old 02-21-2023, 04:17 PM
PM Sent. Thanks, Shawn
