Old 03-14-2023, 03:01 PM
AG's Avatar
AG AG is offline
Originally Posted by 65catalina View Post
[QUOTE
"What I would do instead is have new, quality high durometer rubber bushings put in the stock control arms and add a .5" tall ball joint to the upper control arm. You could also do solid bushings if you wanted, but it's probably overkill for you. Going this route is going to reduce deflection in the system and start correcting the camber curve of the factory suspension in bump and droop without the need for steering angle to do it. It's also going to save you probably $700.00 bucks, which I would use to fund a set of springs, shocks, and a steering rebuild that includes a modernized steering gear.
The whole package I would put together for you based on what you've mentioned is as follows.
-Stock upper and lower control arms, rebuilt with high durometer rubber bushings, .5" tall ball joint on upper arm, factory ball joint on lower arm
-Global West 1" lowering springs front and rear
-Koni Classic shocks (reds)
-Factory steering rebuild (moog)
-Lares or Borgeson .210 torsion bar steering gear with faster ratio (can do Lee or Turn10, but the cost goes way up)
-Helwig front and rear sway bar
Align the front end at these settings
-0.5* Camber
+3* Caster (or as close as the factory arms will allow)
1/16th" toe in
Combined with the 17" wheel and tire package you're looking at, I really feel that you'd enjoy this ride without breaking the bank.
I am going to go this route with my 71 GTO. My question is that I purchased Moog moog-k6148 | Front Control Arm Shaft That provides Additional Camber Adjustment. I have heard it was 2*, and also read that you should install these backwards? to achieve better results. Does anyone have experience with this and how it should be mounted? Thanks, Ed. (Somehow I did that quote function wrong, sorry)[/QUOTE]
I've used the Moog offset arm for more caster and I installed them per the directions, got about 2 more degrees caster.
The Following User Says Thank You to AG For This Useful Post:
