Old 03-25-2023, 12:50 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by highrisk View Post
The speakers you use have to be a shallow depth speaker or they won't work in the kick panel. I originally had bought Alpine speakers and they were too deep.
This is the guy I bought them from. https://garytayman.com/kickpanel.htm
Let me know if you need any additional information.
Take care,
Dale
What speakers did you use? As you mentioned l, the depth is a big issue. Custom Autosound sells the Infinity Reference speakers with the panels and they are too deep for mine by a lot. I only have < 1.5” of depth
Will Rivera
Old 03-25-2023, 12:59 PM
highrisk's Avatar
highrisk highrisk is offline
I used small Kicker speakers that are the size for the kick panel. They fit pretty good. I don't remember the model number. If you need it I can see if I can find the paperwork for them.
Dale
Tremec 5 Speed
U.S. Army Retired
Retired Helicopter Pilot
Old 03-25-2023, 07:32 PM
grivera's Avatar
Please- the Infinitys are 2.5” deep and hit the metal with 1” sticking out past the kick panels.
How do you like the sound of yours?
Will Rivera
Old 03-25-2023, 07:39 PM
highrisk's Avatar
They sound good, but to be honest, I rarely have the stereo on. It interferes with the exhaust sound. 🙄
The paperwork is in the attic. I will try to get up there this weekend and see if I can figure out which speakers I bought.
dale
Tremec 5 Speed
U.S. Army Retired
Old 03-25-2023, 08:08 PM
grivera's Avatar
dale
Might it be these? https://www.crutchfield.com/S-JPYBeJ...saAg1CEALw_wcB
Will Rivera
Old 03-26-2023, 07:40 AM
highrisk's Avatar
They look like these speakers but the grills are a little different.
https://www.crutchfield.com/S-2JthK5...MaAsG3EALw_wcB
Dale
Tremec 5 Speed
U.S. Army Retired
Old 03-26-2023, 09:30 AM
grivera's Avatar
Thanks - very interested in the actual depth
Will Rivera
Old 03-26-2023, 12:52 PM
highrisk's Avatar
I found the paperwork and I bought them at BestBuy. The model number is 43CSC654 which seems to be the same number as the one you attached above. They must have changed the grill since I bought mine.
This is it at Crutchfield, but I think it has been discontinued, https://www.crutchfield.com/S-r3dEr4...-43CSC654.html
This is the new one that cross references at BestBuy, https://www.bestbuy.com/site/kicker-...?skuId=6333353
My paperwork says the top mounting depth is 3/8" and the bottom mounting depth is 1 11/16". If I remember correctly, they fit but they were still up against the insulation.
Hope this helps,
Dale
Tremec 5 Speed
U.S. Army Retired
Old 03-29-2023, 01:42 PM
grivera's Avatar
Thanks Dale - that does help and I was gonna ask if they touched the body.
Will Rivera
Old 04-09-2023, 04:11 PM
grivera's Avatar
I ended up with Infinity Reference shallow depth speakers which are the same ones Custom Autosound sells with their kick panels. I painted the kick panels SEM Saddle as I couldn’t find a good match for the door panels otherwise. I’ll have to get used to the color. The drivers side speaker makes contact with the inner body panel and I put hushmat on both sides.
The parking brake pedal I moved at the dash point about an inch towards center - I had to make a plate for the attach point. Both kick panels are for an AC car.
ID:	610488   Click image for larger version
Will Rivera
