Ames says they have the correct pan that will fit but it doesnt have a baffle.........but on the website it says almost all the pans they have will need to be indented........so im not sure how many pans im gonna have to buy to find something that fits. I also bought new motor mounts from ames, so maybe that might raise the motor up some and help with the issue...........i know you can but spacers for the frame mounts, im wondering how much this would mess with your trans , pinion angle measurments. Rich |
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
Mine originally had a chrome Moroso deep sum with baffle. The PO had the pan on and off so many times (multiple spun bearing incidents) that the metal was soft around the bolt holes. A slight tug of the socket wrench just deformed the rails. When I rebuilt the motor, I threw the pan out and found a good deal on a Milodon low profile with the side kickouts. The matching pickup bolted to a main cap. Installed it with a BOP one-piece gasket as I outlined and never leaked a drop again.
Triple Black 1971 GTO |
Rich Neighbors Complant............ya got a # on that moroso pan...........i can go either way........with pans that is. Rich |
Milodon Oil Pickup Press Fit Aftermarket Pan Style Pontiac V8 #18425 About the same price as Canton pan. I found mine NIB for $150 so I went with it.
Im wondering if i have some issue with my frame, cant believe people with 66/67 are buying these oil pans and not having issues................. Hoping this works out ok. Rich |
