Old 06-06-2023, 02:13 PM
69gp400's Avatar
69gp400 69gp400 is offline
Default 69 gp gas gauge stuck on full
finally took out the gp today and ran out of gas. i thought i filled it three years ago when i put it away. would this be the sending unit float stuck? thanks
Old 06-06-2023, 03:26 PM
Scott Thelander's Avatar
I think the trick is to unplug the tan wire in your trunk
Coming from the taillight loom
That wire should go to the sender
Unplug
Turn key on
Any difference??
Old 06-07-2023, 07:45 AM
69gp400's Avatar
i"ll give it a try today. wqhat difference should i see? thanks
Old 06-07-2023, 09:16 AM
1969GiPper 1969GiPper is offline
Unplug
Turn key on
Any difference??
If you unplug the tan wire and turn the ignition key to ON the fuel gage should go to beyond full. Then if you ground the tan wire going to the taillight loom the gage should go to beyond empty. If you get both results your fuel gage in the dash and all the wiring from the gage to the connector in the trunk is good. Your problem is either in the wire going from the connector in the trunk to the sender in the tank or the sender itself. That’s assuming you have fuel in the tank.
The Following 2 Users Say Thank You to 1969GiPper For This Useful Post:
Old 06-12-2023, 01:52 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Or a broken or dirty ground where the black wire from the sender bolts to the floor pan or somewhere.
Old 06-13-2023, 02:12 PM
69gp400's Avatar
well i thought i would get to it but plans changed. definatly this week for sure i will update the results. thanks
