Old 06-09-2023, 06:42 PM
skinny035 skinny035 is offline
Default fan shroud gap
I have a 65 GTO with a 455 with AC and automatic. I installed a cold case radiator and now have a 1" gap between the top of the shroud and the radiator? I'm sure this is decreasing airflow through the shroud. Is there something I'm missing? An adjustment?
Old 06-09-2023, 06:47 PM
i noticed that the Harrison radiator is thicker than the cold case if that means anything
Old 06-13-2023, 04:30 PM
geeteeohguy's Avatar
You have non oem parts mismatch. Easily fixed with a strip of heavy rubber mudflap material or a strip of metal. You want the gap sealed for the shroud to work.
Jeff
Old 06-13-2023, 04:34 PM
It just looks kinda bad that way. Where does the fault lay, the radiator of fan shroud?
Old 06-15-2023, 10:28 AM
grivera's Avatar
grivera grivera is offline
I have the same issue in my 64 with a Champion aluminum radiator.
Any pics of the mudflat or metal mod?
Will Rivera
Old 06-19-2023, 02:34 PM
jarhead's Avatar
jarhead jarhead is offline
Ames has the AC seal kits - https://secure.amesperf.com/qilan/De...A&web_access=Y
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900
The Following User Says Thank You to jarhead For This Useful Post:
Old 06-19-2023, 04:23 PM
lucky1 lucky1 is offline
Default Gap.
I experienced the same thing. The replacement was not as thick as my original Harrison. It also had a gap as it sits on the core support.
It cooled better than the original because it more efficiently dissipates heat and does not have to be as thick to accomplish it.
Old 06-20-2023, 02:38 PM
Here is a pic..It looks aweful
Old 07-02-2023, 01:50 PM
Not sure if you can see it very well. Just a heavy bit of rubber filling the gap. Foam insulation for outside pipes works, too.
Jeff
Old 07-06-2023, 01:16 PM
grivera's Avatar
Originally Posted by jarhead View Post
Thanks - the seal kit is $49 which seems reasonable and the fastener kit is $73 - wow https://secure.amesperf.com/qilan/De...A&web_access=Y
Attachment 615278
I can't make it out in the pic
Will Rivera
