Old 06-14-2023, 07:54 PM
64speed's Avatar
64speed 64speed is offline
Default Brake Pedal Removal
Working on my FIL' Firebird. What does it take to get the brake pedal out of the car to switch from a manual to automatic pedal. In my Tempest the brake pedal pushrod is held on by a cotter pin. On this car there is a pin with the common clip but once its off there is no room to push the pin out as the pin hits the column assembly. Is there a trick I am missing?
Old 06-15-2023, 06:20 PM
64speed's Avatar
Bueller, Bueller
Old 06-15-2023, 06:26 PM
What year? 67-68 are different from 69.
If it’s a 67-68 the brake pedal should be able to be removed from the carrier and simply replaced with the proper dual set.
If it’s a 69, unless you can find the 69 specific pedals (not reproduced) you have to remove the carrier and replace it with a 69 Camaro carrier and its pedal set. That’s a more involved project.
-Jason
1969 Pontiac Firebird
Old 06-16-2023, 05:55 AM
64speed's Avatar
It’s a 68
Old 06-16-2023, 09:43 AM
If it's a 68, you can source reproduction pedals from any of the typical places. They should be held together with a pin in the pedal carrier. Other than having to crawl under the dash, it should be a straight forward swap. Pull the pin for the brake pedal, remove and replace with the new pedals, insert pin, then hook the pedals to their respective linkages.
-Jason
Old 06-16-2023, 12:04 PM
64speed's Avatar
I have the pedal. The pin is the problem. It doesnt have enough room to slide out of the carrier assembly because it hits.
Old 06-17-2023, 10:51 AM
64speed's Avatar
Sometimes I’m daft. I got it
