#201
Old 08-12-2023, 02:50 PM
Shockwave78 Shockwave78 is offline
Originally Posted by Gach View Post
Pull the dipstick and smell the oil on it. See if it smells like fuel. Wow ! You had allot going on. carburetor issues intake leaking valve adjustment, glad to see its not the cam. Yeah I would change the oil anyway, taking chance of the rings getting wash out. Put fresh set of plugs in there too.
looks like I'm done for now, the #1 cylinder is hashed, and it was sucking oil down the intake
  #202
Old 08-12-2023, 03:35 PM
Gach's Avatar
Gach Gach is offline
That sucks !
  #203
Old 08-12-2023, 03:54 PM
What would the maximum bore oversize that would work with file fit piston rings and stock pistons?
  #204
Old 08-12-2023, 03:58 PM
78w72 78w72 is offline
whats hashed about #1 that it needs bored? would a hone & new rings work?
  #205
Old 08-12-2023, 04:00 PM
Gach's Avatar
It depends on what the piston company recommends. As and example say they say .005 piston to wall, maybe you could get away with say .002 over if that would clean up the cylinder walls. Is that what your thinking on doing, use same pistons, clean up cylinder walls and some file fitted rings ?
  #206
Old 08-12-2023, 04:02 PM
Yep, the engine still has the stock pistons installed.
  #207
Old 08-12-2023, 04:06 PM
Gach's Avatar
I mean I’ve seen guys just hone cylinders out and re-ring and not have issues. But main thing is to check cylinder and make sure there’s no taper. Most important part is make sure it has right cylinder wall finish so rings will seat.
  #208
Old 08-12-2023, 04:10 PM
Gach's Avatar
If it where me though, if your going to go through all that, I would just go .030 over and just put new pistons in it. Going with a hone and re-ringing it, is like flipping a coin. May be good for a while.
  #209
Old 08-12-2023, 04:11 PM
Stan Weiss's Avatar
Please do a cranking compression test on #1 cylinder and tells us what you get.
Stan
Pontiac Pump Gas List
  #210
Old 08-12-2023, 04:19 PM
Gach's Avatar
Question when you say all hashed up, did you pull the head off or look down with a camera. Just trying to visualize what you mean by hashed up.
  #211
Old 08-12-2023, 04:32 PM
Stan
150 psi same as always
  #212
Old 08-12-2023, 04:36 PM
I have a borescope that I used, there was no cross hatch left at all, just vertical score marks
  #213
I am in the process of pulling the heads to get a better look
  #214
Old 08-12-2023, 04:42 PM
Gach's Avatar
Ok, now I get it. Sounds like rings got washed out. I think that will clean up with a good hone job, specially seeing that the compression still up there and good.
  #215
Old 08-12-2023, 04:43 PM
Stan Weiss's Avatar
Did you check any of the other cylinders with the bore scope? To see if they look the same as #1 or not?
Stan
  #216
Old 08-12-2023, 04:46 PM
Gach's Avatar
Stan
He’s pulling the heads.
  #217
Old 08-12-2023, 04:51 PM
Stan
Not yet, I will though and let you know
  #218
Old 08-12-2023, 06:12 PM
Stan Weiss's Avatar
Is it possible for you to take and post a picture?
Stan
  #219
Old 08-12-2023, 08:12 PM
Dragncar Dragncar is offline
I have set of new plain iron rings for a std bore 400 in the garage.
If you decide to just hone it with new rings you can have them , just pay shipping.
I would like them to go to someone who could use them.
I never will.
  #220
Old 08-12-2023, 08:50 PM
I never will.
I appreciate the offer but I had to get file to fit rings for the first rebuild so std bore rings won't work. I'm thinking of just selling the car anyways, I've sunk a couple grand and about 2 months just to get back where I started.
