Old 08-29-2023, 06:55 AM
Mr Twister's Avatar
Default Thoughts on broken block boss
I’m considering getting this block for a spare but the owner sent me this picture. Is this repairable? It’s a 73 400.
Old 08-29-2023, 08:15 AM
What year car is it going in as you may not need that boss?
Old 08-29-2023, 08:18 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I ran a 455 almost just like that for 30 yrs. In an A body. So, I didn`t worry about it as I was using the 2 bolt mounts. This is at 470 to 500 hp level with solid mounts.
I sold that motor to member GTO TEX here. He`s using it in a 2`nd gen Trans Am. I showed him the boss before he bought it. He bought it anyway.
He`s telling me the damn thing goes 12.7`s in the quarter with 2.41 gears at full weight. So, the motor is no slouch.
Maybe give him a pm to see what he did.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 08-29-2023, 09:34 AM
track73 track73 is offline
I fixed a Chevy starter bolt hole by putting a 3/8 x16 stud into a engine lathe and drilling a 1/8th hole into the center. Then I tig welded it into the block with Ni rod. When it cooled I drawfiled it flush with the rest of the block. I then drilled it out with a 5/16 drill bit and tapped it to 3/8 x16.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
The Following User Says Thank You to track73 For This Useful Post:
Old 08-29-2023, 10:24 AM
Formulas's Avatar
Formulas Formulas is offline
Whats the story with the rest of the block?
Anything else put it close to the dumpster?
Other than the other mount bolts falling out and that one breaking while running a bone head move caused that breakage and one would have to wonder iff theres more
Old 08-30-2023, 08:56 AM
mgarblik mgarblik is offline
If that hole is not needed, just smooth off the rough edges and leave it. If that hole is needed for an engine mount bolt: clean the hell out of the area and weld the entire area up with a silicon bronze welding rod. Shape and form a new lug with a die grinder. Drill and re-tap the hole. Good as new. I would not scrap a block with just that little rat bite on it. Easily repaired.
Old 08-30-2023, 09:03 AM
Mr Twister's Avatar
Thanks everyone I'm going to get the block if the rest checks out.
Old 09-05-2023, 10:12 AM
GTO TEX's Avatar
GTO TEX GTO TEX is offline
Didn't need the broken boss since it was going into an F body. This is the mounts I used https://butlerperformance.com/i-2445...tegory:1393551
ID:	619458   Click image for larger version
Mike Iden
'66 GTO Post/468, 700R4, 3.31 7.25@96mph 1/8
'24 Chevy 4X4 Crew RST Z71
Old 09-05-2023, 11:58 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
One last thought if the boss is needed...
Put a longer bolt in it, weld the boss up with the bolt in, then cut off the head of the bolt. Now you have a stud.
Lots of options. As mentioned, certainly not a big deal with street HP.
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
The Following User Says Thank You to Mister Pontiac For This Useful Post:
Old 09-05-2023, 03:50 PM
I like that fix. That would be fast and easy with a silicon/bronze rod. A little pre-heat to the boss area, weld it up, cut off the bolt head, dress it a little, run a die over the first couple threads your done.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 09-26-2023, 06:50 AM
2048tm 2048tm is offline
I like that fix. That would be fast and easy with a silicon/bronze rod. A little pre-heat to the boss area, weld it up, cut off the bolt head, dress it a little, run a die over the first couple threads your done. connections game
Your advice has helped me a lot. Thanks.
