Old 09-02-2023, 08:55 AM
nh68gto's Avatar
nh68gto nh68gto is offline
Question TH 400 wire
Is the kick down wire part of the dash harness ?
Colors or way to ID it.
Thanks.
Send it! It’s going home on a trailer.
Old 09-02-2023, 09:07 AM
thepontiacman's Avatar
Usually pink and orange two wire plug.
Plugs into kick down switch that mounts to pedal assembly.
Sent from my moto g power 5G - 2023 using Tapatalk
Old 09-02-2023, 09:49 AM
graygator graygator is offline
Yes, part of the dash harness. Confirm what thepontiacman said. My pink had a dark blue? stripe on it. Connector is flat.
Kent R.
Old 09-02-2023, 09:50 AM
nh68gto's Avatar
Ok then what goes to the trans ?
Old 09-02-2023, 11:02 AM
1 blue or black wire goes to transmission.
Wiring diagram will show where it attached to engine harness outside on firewall.
What car do you have?
Old 09-02-2023, 11:33 AM
nh68gto's Avatar
Ok
69 GTO
Old 09-02-2023, 03:20 PM
Kenth's Avatar
Kenth Kenth is online now
On the kick-down switch you´ll have a Pink Dubbel Black from IGN and an Orange wire to the bulkhead connector position A-Y and from the engine side bulkhead connector position A-Y goes a Black Single Orange wire to the solenoid connector on transmission.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 09-03-2023, 01:40 PM
nh68gto's Avatar
Ok. I will look over the harness.
Ty !
