Old 09-17-2023, 09:12 PM
johnta1 johnta1 is online now
Does it go past full with key on?
If so probably disconnected wire at sender or broken wire.
Old 09-17-2023, 09:38 PM
grd777 grd777 is offline
no stays at full
Old 09-18-2023, 06:38 AM
Is the tank full?
I'd check that there is 12 volts at the dark brown wire at the gauge. The tan wire goes to the sender at the tank. The dash gauge needs to be grounded to dash and dash should have a ground also.
The sender on gas tank should be grounded also. The ground point may be corroded?
If the tan wire is grounded it should show empty I believe. (zero resistance)
At 'Full' it shows 90 ohms to the gauge.
Old 09-18-2023, 06:41 AM
If it is at Full, the sender may be stuck up which would show full I guess?
(if the others stuff checks out OK)
Old 09-18-2023, 04:20 PM
i will add more gas and see if it goes up
