Old 09-17-2023, 08:32 PM
grd777 grd777 is offline
Default issues with my fuel gauge
when the car is off (key out ) it reads 1/4 tank, which is correct .when i start the car it goes to full . i have replaced the tank and the sending unit ,it it also grounded .what should i check
Old 09-17-2023, 09:12 PM
Does it go past full with key on?
If so probably disconnected wire at sender or broken wire.
Old 09-17-2023, 09:38 PM
no stays at full
Old 09-18-2023, 06:38 AM
Is the tank full?
I'd check that there is 12 volts at the dark brown wire at the gauge. The tan wire goes to the sender at the tank. The dash gauge needs to be grounded to dash and dash should have a ground also.
The sender on gas tank should be grounded also. The ground point may be corroded?
If the tan wire is grounded it should show empty I believe. (zero resistance)
At 'Full' it shows 90 ohms to the gauge.
Old 09-18-2023, 06:41 AM
If it is at Full, the sender may be stuck up which would show full I guess?
(if the others stuff checks out OK)
Old 09-18-2023, 04:20 PM
i will add more gas and see if it goes up
Old 09-18-2023, 05:15 PM
Transamric's Avatar
Is the new sender an aftermarket replacement or a NOS GM?
Old 09-18-2023, 05:19 PM
aftermarket
Old 09-18-2023, 05:20 PM
Transamric's Avatar
That may be the problem. It took me 3 senders to get one to read accurately on my '70.
Old 09-18-2023, 05:23 PM
ok that will be a pain if i have to replace it . is anything i can try before i do
Old 09-18-2023, 09:57 PM
Trevor78 Trevor78 is offline
A faulty ground, or disconnected ground wire at the sender would cause the needle to max out, off the face of the gauge, and not change if keys removed. The fact it drops again to what is assumed the correct level, shows that something is being introduced to the feed that shouldn't be there with ignition, a crossed-wired somewhere perhaps, but where, no idea. I guess that could also be at the sender itself. Was you harness to it still intact, has the rubber boot?
Old 09-18-2023, 10:25 PM
yes i am thinking something like that. now i need to find out step by step
Old 09-18-2023, 10:45 PM
Some simple tests, that don't tell much, is to disconnect the sender wire at the trunk harness. With ignition, the gauge will max out, and without power, should stay there. Plugged back in, when working normally, it would pull back down to correct level. Normally.
The Following User Says Thank You to Trevor78 For This Useful Post:
Old 09-18-2023, 10:47 PM
k thanks will give it a shoot
Old 09-19-2023, 12:56 PM
tdavidl's Avatar
tdavidl tdavidl is offline
i hope you can get it to work...if not, its not the end of the world...mine works, however, i don't know if mine is original or an aftermarket...same with gas tank & i don't have 100% confidence in how it reads so i just make sure i fill the tank every times to odometer turns over another 100 miles...never have to worry if the gas gauge us accurate then :-)
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 09-19-2023, 04:02 PM
yes one of my cars in the past had this issue and i seemed to mange ,thanks for reminding me
Old 09-19-2023, 07:28 PM
Formulabruce's Avatar
Sender GROUND is at Back of unibody near the tail panel on a unibody extension, not far from filler neck.
" Long may we DRIVE !"
Old 09-19-2023, 07:43 PM
yes i see it will try to clean it up
