Old 09-24-2023, 11:11 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
You can go to www.ultimategto.com and use a dream car option that will show you all the 71's on their site that are Lauren Green.
About 16 or 17 across all nameplates and body styles that color.
You have one of the top color combos for a 71 GT-37
But its your choice
Thanks so much! VERY helpful site! You mean Black w/ Gold stripe is one of the top combos?
Old 09-25-2023, 08:41 AM
Yes
Black & Gold would probably be in everyone's top 3
The Following 2 Users Say Thank You to Baron Von Zeppelin For This Useful Post:
Old 09-25-2023, 07:33 PM
79 Phoenix's Avatar
Yes
Okay, good to know... Looks like I should stick with black! Thanks
Old 10-07-2023, 02:15 PM
79 Phoenix's Avatar
Default oil pump recommendation
I have pulled the pan and rod and main caps off my "new" engine... I am going to replace the oil pump and screen... Any recommendations on the oil pump? I see there are 60# rated and 80# rated pumps. Which would give me the best oil pressure on this Pontiac motor? This is a stock 2bbl 350 .
Would a Melling pump be the best?
Also, it appears the rope rear seal has been working well. Unfortunately it looks like I will have to have the rod journals turned. So crank will have to come out.
Old 10-13-2023, 04:01 PM
79 Phoenix's Avatar
Okay--Thanks so much for the charts and the info! yes, the partial VIN matches the 160219 on my dash VIN plate.
WN I guess is one of multiple suffix used on various A body 71 250 HP w/4spd designated blocks. ... I see it in the chart listed for a 71 250 HP 350 w/4 speed and mine's a 3 speed but maybe in 71 they didn't differentiate between 3sp and 4 spd with regard to the suffix.
Thank you guys for your time and patience helping me figure out what I've got in these 2 engines. I really appreciate it!
Old 11-06-2023, 07:58 PM
79 Phoenix's Avatar
Well, I bought a 76 557 block 400! Seems very solid. So extra motivation to get the rest of the car ready for the engine and hopefully fire it up by spring...maybe before.
Now I need to figure out what to do with the two 350's I have... The original and the one I bought last spring.
Name:	Pontiac 400  home.jpg
Old 11-06-2023, 10:14 PM
You might want to use a pair of the 350 heads on the 400 engine , for better compression ratio / power.
Unless the new 400 is already sitting on go.
It will probably just barely be around 8:1 comp ratio as-is.
Congrats on finding a suitable replacement engine
Old 11-07-2023, 12:35 PM
79 Phoenix's Avatar
Thanks! Engine ID is...1976 A or B Body 2 bbl carb 170 HP Heads= 6X Block# = 500557 Code# = X4
So, a low performance 400, which is okay... It runs good and I don't want to put more money into the #94 heads so I will leave building it up more to the next owner... On video, engine sounded real healthy but not lopey... so I assume it's pretty much stock. It had a serious rebuild several years ago and does have an Edelbrock intake though. I don't know if any enhancements were made to the 6X heads or the cam. I know cam, lifters and cam bearings were new with rebuild... So we'll see come spring...
Old 10-04-2023, 04:58 PM
Yes, mine was factory crank, two piece, and likely un-prepared as hell...
