Old 10-28-2023, 11:32 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
That seems like a fair price for the stated condition for the complete engine and trans. Maybe see if he'll take $1500?
If you do buy it, re-list the trans to see if you can get a couple hundred back. Maybe you end up with a complete running 400 for around $1200-$1300? Hard to argue that if it's as described and you can drive the car that way for a few years. (He did mention he wishes he would have stuck with this engine in his car. That says something)
But you're right. It's not the most desirable block. Still, for what you're doing, it would fit the bill very well. If it's as good as he states, I would just drop it in without doing a thing to it, and then drive! Let the rear main leak a bit. At least the car will be back on the road in a weekend if everything else is ready to roll.
Of course this is only what I would do simply to get the car quickly back on the road. If that's not your main purpose, and you want something a little nicer and 'more correct,' spend the time to search for a 1971 400 or 455, build it as you desire, then call it done. My only thought is that is a lot longer in time and dollars vs buy something like this 400, drop it in and go!
You can always build that perfect 455 a couple years down the road, then sell off the 400...
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
  #222
Old 10-29-2023, 04:05 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Okay..thanks. i asked him what car it came out of and how long its been out. Also asked him what was done to the engine when it was rebuilt.Here are some more answers ...
1. I have a 1971 Firebird
2. About 2 months
3. I have a list from the previous owner and can only go by his word, he builds firebirds for a living so I took what he said at face value- rings, cam bearings, lifters, camshaft timing chain sprocket, new ignition module, has rebuilt alternator , rebuilt starter. The motor is very clean & ran strong.
  #223
Old 10-29-2023, 04:50 PM
79 Phoenix's Avatar
He said oil pressure around 35 (asked him to clarify hot, idle, cold??) He said temp a little over 200 degrees. Got the video of it running...Actually sound quite nice & healthy... not noisy... Is there a way I can attach a video? It's in 3GP format.
  #224
Old 10-30-2023, 08:46 AM
79 Phoenix's Avatar
With this 76 engine I assume I would need to get a new flywheel with a smaller register hole because the newer crank registers are smaller. Is this correct?
Also, the block is a 76 and has been used with an automatic trans so would I need to drill and tap a hole in the block for the clutch linkage? Would there be a boss on the block that I could drill into?
Any other compatibility issues I should be aware of?
  #225
Old 10-30-2023, 11:06 AM
79 Phoenix's Avatar
If I buy this engine I would rather not change the rear seal unless it's really bad. Has anyone changed a rope seal with crankshaft in?
  #226
Old 10-30-2023, 11:12 AM
79 Phoenix's Avatar
He said oil pressure is 35# at idle when hot. Has 47k mi on since rebuild.
ALSO, would my 71 bell housing bolt up to the 76 block?
  #227
Old 11-06-2023, 07:58 PM
79 Phoenix's Avatar
Well, I bought a 76 557 block 400! Seems very solid. So extra motivation to get the rest of the car ready for the engine and hopefully fire it up by spring...maybe before.
Now I need to figure out what to do with the two 350's I have... The original and the one I bought last spring.
Name:	Pontiac 400  home.jpg
  #228
Old 11-06-2023, 10:14 PM
You might want to use a pair of the 350 heads on the 400 engine , for better compression ratio / power.
Unless the new 400 is already sitting on go.
It will probably just barely be around 8:1 comp ratio as-is.
Congrats on finding a suitable replacement engine
  #229
Old 11-07-2023, 12:35 PM
79 Phoenix's Avatar
Thanks! Engine ID is...1976 A or B Body 2 bbl carb 170 HP Heads= 6X Block# = 500557 Code# = X4
So, a low performance 400, which is okay... It runs good and I don't want to put more money into the #94 heads so I will leave building it up more to the next owner... On video, engine sounded real healthy but not lopey... so I assume it's pretty much stock. It had a serious rebuild several years ago and does have an Edelbrock intake though. I don't know if any enhancements were made to the 6X heads or the cam. I know cam, lifters and cam bearings were new with rebuild... So we'll see come spring...
  #230
Old 11-07-2023, 01:01 PM
Did the '76 400 engine block have the 5 bolt style motor mount pattern or the late mounts 3 bolt only style?
  #231
Old 11-07-2023, 04:44 PM
79 Phoenix's Avatar
Both sides are 5 holes drilled and tapped.
The Following User Says Thank You to 79 Phoenix For This Useful Post:
  #232
Old 11-07-2023, 05:50 PM
That's great, makes it much easier to bolt into your '71 1/2 GT-37
When you get a chance, coulld you relay the alpha numeric 4 digit date code on the block back by the distributor?
  #233
Old 11-07-2023, 07:59 PM
79 Phoenix's Avatar
Code looks like A156 January 15, 1976?
Name:	400 Block Date.jpg
  #234
Old 12-09-2023, 09:41 PM
79 Phoenix's Avatar
The work continues! Cleaned, wire brushed, primed, painted firewall, heater box and pedals under driver side dash. Replaced heater core and blower motor, pedal bushings and connecting hardware. Also installed oil, water temp and volt gauges and ran tubing and wiring out through firewall grommet.
Installed new master cylinder and clutch rod boot.
Radiator support mounting holes were completely rotted out on both sides. After careful measurements, I used big washers with the right sized holes and had them welded in. I have test fitted and it is very closely lined up. I may need to oval out the mounting holes a little to provide move side to side adjustment. Also need to finish cleaning and painting radiator support.
After going round and round (no pun intended) on which flywheel to buy, I decided to use the original flywheel. To do that, I needed the spacer ring from Butler to make up for the 1/4" smaller register hole difference on my 76 engine. Flywheel is currently at machine shop where they will insert and spot weld the spacer, resurface and balance the flywheel.
Next, after brake and fuel line installation come the gas tank, rear springs and shocks.
ID:	624741   Click image for larger version
ID:	624742   Click image for larger version
  #235
Old 01-14-2024, 07:54 PM
79 Phoenix's Avatar
Default latest progress
Well things are moving along slowly but surely. Gas line and brake line in (except across rear axle). Steering box and tie rods in and rear springs and shocks in. Rear brakes in. Next is gas tank. It's nice to be finally putting more of the new parts on!
Name:	Gas and brake line.jpg
ID:	626595   Click image for larger version
ID:	626596   Click image for larger version
Name:	rear springs and shocks.jpg
ID:	626597   Click image for larger version
  #236
Old 01-22-2024, 08:17 PM
79 Phoenix's Avatar
Smile
Finally getting to the transmission. Opened it up today and it looks great! Also minimum end play on input shaft. I fished a magnet down inside and just a few tiny filings... almost like dust. I'm not surprised because the car, to this point, has only been driven by the original owner--a Catholic priest who didn't abuse the car. I will continue the cleanup , replace side cover gasket, rear seal and "o" ring in bearing retainer. Once clean it will get a paint job.
I will also clean up the Hurst shifter and replace a couple of the bushings and all the clips.
Also got front brake hoses on, tightened steering linkage and installed cotter pins and installed gas tank--not as easy as I expected (but what is?).
ID:	626973   Click image for larger version
ID:	626974   Click image for larger version
  #237
Old 02-26-2024, 05:17 PM
79 Phoenix's Avatar
As the work continues, I replaced front and rear Transmission seals and side cover gasket. Also cleaned and painted the transmission a cast iron color since that's what it is.
I also replaced the rubber bushings in the shifter after cleaning it up and loosening it up with Blaster. Cleaned and painted the shift rods and arms replacing the clips..
Then the tedious task of cleaning and painting the engine which I'm still in the middle of. I decided to use the lighter non-metallic blue engine paint (Dupli-Color SP-122) because my memory (such as it is) tells me it is closest to what the 350 in my 71 GT-37 was 45 years ago...
I'm also getting the alternator and brackets ready for re-assembly.
Hopefully the engine and trans will be bolted back in sometime in March.
ID:	629409   Click image for larger version
Name:	engine paint.jpg
ID:	629410   Click image for larger version
The Following 2 Users Say Thank You to 79 Phoenix For This Useful Post:
  #238
Old 03-01-2024, 08:58 PM
A lot of big improvements going on with that car.
You're a man on a mission .
Which engine did you decide to go with ?
  #239
Old 03-02-2024, 03:44 PM
79 Phoenix's Avatar
I went with the 400. It's a 76 2bbl engine originally out of an A or B body car... Not sure of any mods but I know the cam has been replaced about 5 yrs ago when engine was rebuilt and it has an Edelbrock intake with Quadrajet. I does have 6X heads which are probably stock. I'm thinking it's pretty much a stock late 70's 400--nothing high performance. As long as it runs good I'll be happy.
I was able to sell the other 350 I had purchased so I just have the original numbers matching 350 sitting in my driveway under a tarp.
  #240
Old 03-02-2024, 04:58 PM
79 Phoenix's Avatar
I put a second coat of paint on the engine. I used a different can but same color and it is different but closer to the blue I remember... (a little more greenish). Anyway I'm even more happy with the color after the second coat.
Name:	engine paint II.jpg
