#161
Old 10-03-2023, 08:01 AM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Originally Posted by tstroud View Post
If you use either the one piece or two piece seals you will need to remove the serrations on the crankshaft in the seal area or it will eventually leak. Ask me how I know.
Serrations on the crank?? What was the purpose? Do you have a picture?
  #162
Old 10-03-2023, 08:20 AM
tstroud tstroud is offline
http://www.tinindianperformance.com/...ar-main-seal/#
The Following User Says Thank You to tstroud For This Useful Post:
  #163
Old 10-03-2023, 11:56 AM
I would highly recommend however if it is not leaking now you are playing the "will it leak" game either way - pontipigs are famous for this.
Some guys tilt them for a couple days just see the leaking before shoe horning them back in.
My mechanic forgot to change the seal, then it leaked like crazy, then bought the two piece after-the-fact, and it still leaks...fml
Old 10-03-2023, 12:07 PM
Verdero fighting with his rn apparently:
https://forums.maxperformanceinc.com...d.php?t=869548
Old 10-04-2023, 10:04 AM
79 Phoenix's Avatar
Whew... Thanks guys for the education on Pontiac rear seals! I looked closer and there does seem to have been a little seepage on back side of the pan... possibly the rear seal. Doesn't look like it was terrible though.
After reading what you guys sent, I'm having second thoughts about messing with the rear seal. The reason I bought this engine is that it ran pretty good (according to previous owner and video he sent) and I didn't want to put a lot of money into a 350. Maybe I will just check out the rod bearings and leave the mains and rear seal alone.
  #166
Old 10-04-2023, 11:45 AM
I have given up for the time being...built in oil change lol
Maybe I'll give it another go when I win the lotto and get a new butler, and a butler while I'm at it 🙄
Old 10-04-2023, 02:45 PM
Verdoro 68's Avatar
It was a battle, but I *think* I've finally conquered the seal (knock on wood).
What I learned is that the graphtite seal isn't as foolproof as it may seem. Then again, maybe I'm just a special level of fool LOL.
Given my experience, I wouldn't recommend installing any real main seal with a crank in place because of the cleaning and the prep required in the cap and the block. I'm sure it has be done successfully, just seems to add another layer of risk to a labor intensive procedure. You can't install the one piece with the crank in place anyway.
Lots of people say you can't use the Viton seal with serrated cranks, but Wade at BOP will tell you differently. The factory crank serrations are also way less aggressive than aftermarket cranks and more amenable to Viton. That said, I did have my Eagle crank polished down before I installed the one piece for insurance.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #168
Old 10-04-2023, 04:58 PM
Yes, mine was factory crank, two piece, and likely un-prepared as hell...
Old 10-07-2023, 02:15 PM
79 Phoenix's Avatar
Default oil pump recommendation
I have pulled the pan and rod and main caps off my "new" engine... I am going to replace the oil pump and screen... Any recommendations on the oil pump? I see there are 60# rated and 80# rated pumps. Which would give me the best oil pressure on this Pontiac motor? This is a stock 2bbl 350 .
Would a Melling pump be the best?
Also, it appears the rope rear seal has been working well. Unfortunately it looks like I will have to have the rod journals turned. So crank will have to come out.
  #170
Old 10-08-2023, 12:46 AM
Verdoro 68's Avatar
M54DS seems to be the reliable go to pump. I went with a Butler prepared 60 lb pump and hardened driveshaft on my build. A little pricey, but I liked the improvements they added. You’ll get lots of opinions on 60 vs 80. IMO a 60 would suits most builds just fine.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #171
Old 10-09-2023, 06:05 PM
79 Phoenix's Avatar
Okay, thanks. Mine currently is an M54D. Is there a difference between a M54D and an M54DS?
  #172
Old 10-10-2023, 07:07 PM
79 Phoenix's Avatar
Default further developments ...
I got the crank out of my "new" used engine and took to the machine shop. It can be cut .01 on rod and main journals. BUT according to the casting number on the crank (#4813) my engine is a 74-76 350, not a 68- 71 like I thought. Apparently, the casting on the crank where the flexplate or flywheel bolt on changed in 1974 to a little different diameter so my flywheel (in back of original engine) won't bolt on.
Does this make sense??
  #173
Old 10-10-2023, 11:03 PM
Verdoro 68's Avatar
Same pump. I believe the S is the catalog number meaning it came with a pickup/screen.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #174
Old 10-11-2023, 04:22 PM
79 Phoenix's Avatar
That makes sense-_Thanks!
  #175
Old 10-11-2023, 04:24 PM
79 Phoenix's Avatar
Default Crankshaft Change??
Does anyone know if the 350 crankshafts changed after 1973? Or if there is any difference in the crank on a std trans engine VS an automatic engine?
  #176
Old 10-11-2023, 05:09 PM
Seems like I have heard about different size registers for flywheels before , but I don't remember how the story goes .
Did you ever go through all the date code drills on this new-used engine to ID the block and heads ?
Crankshaft should have more numbers in the casting number than what you posted.
At least 7 digits
After you get all your dates and numbers nailed down , you could post the question in the "Street Section"
  #177
Old 10-11-2023, 05:59 PM
79 Phoenix's Avatar
At least 7 digits
Unfortunately, I did not check this out before I bought the engine. I assumed it was a 71 engine. Okay, thanks that's helpful. I will look for more numbers... Also I am not that familiar with Pontiac engines. So I am learning.
  #178
Old 10-11-2023, 11:42 PM
The block code is STAMPED on the flat machined front face of the block.
Location is upper passenger side - where head bolts to block.
A 7 or 8 digit sequence number stamping , then a 2 digit application code.
The 2 digit code is the main ingredient.
For example will look something like this :
07798562
___ YN ___
The block casting date is located near the distributor hole.
It is CAST on the block in raised digits.
It will be 4 digits - with a fake looking screw head on each end.
Will look something like this :
@ B172 @
The head application code is CAST onto the head in bigger raised digits.
Located on top of the two center exhaust outlet ports.
For example :
11 .... or 33 ... or 4X
The head date code is CAST onto the head - on the outside - an inch or so below the valve cover.
It will look exactly like the Block Date Code described above.
You can check these on both your engines.
  #179
Old 10-12-2023, 01:27 PM
Some pictures to help.
Block ID and partial VIN
Head ID
Head date code
The date code on the block - near distributor hole - will also look like this example.
  #180
Old 10-13-2023, 11:03 AM
79 Phoenix's Avatar
Thanks Baron! -- I did check out the crank on the Street section... The guys they’re very helpful with info. 100% sure I have a 71 crank and 99% sure it's a 350 crank. Now I will check out the block... which I know is a 350 block because of the bore. I also know the heads are 94's.
I know a lot of these things are basic but are a needed education for me.
