#141
It's like a 10-60 lubricant.
#142
Okay-- I had seen that in my service manual but what is "water resistant FP grease"? Is it chassis lube?
#143
No, it's more like rear-end grease, just not as thick.
#144
EP is Extreme Pressure rating.
Probably whatever you use in your manual trans will work fine. Maybe inquire to a place that rebuilds manual steering boxes about their recommendation. |
#145
Okay guys...Thanks so much. I appreciate your input!
#146
I am considering painting my car Laurentian Green instead of the original Starlight Black. Any one have pictures of a Lemans or GTO in Lauerntian Green?
#147
You can go to www.ultimategto.com and use a dream car option that will show you all the 71's on their site that are Lauren Green.
About 16 or 17 across all nameplates and body styles that color. You have one of the top color combos for a 71 GT-37 But its your choice |
#148
Yes
Black & Gold would probably be in everyone's top 3 |
#150
anyone that wants to reject a factory black one,I ll take it.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
#151
Okay, good to know... Looks like I should stick with black! Thanks
#152
Okay, point made! Thanks for your helpful input!
#153
Got the A-Arm bushings put in along with lower ball joints and re-assembled the front suspension with new springs...Glad that's done! Need to repair the radiator support but that should not be too big a deal for a welder. Also got my wheels painted and clear coated...
Next to drain the oil out of the new engine. It seems to be pretty healthy according to video I saw and the previous owner, but I am going to pull the pan and replace main and rod bearings while they are accessible...That way I'll know what I've got. * |
#154
Does anyone know what this is?
#155
I believe that is the horn relay.
#156
Oooh...That must be a plastic cover around it. I've never seen one with a cover but looking on ebay I see they sell them with covers. THANKS!
#157
how is the rear main seal
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#158
Good question: I don't see evidence on the engine and I think the guy I bought it from told me no oil leaks... On a Pontiac motor can you replace the rear seal without removing the crank?
#159
As far as I can tell there are 3 types of rear seals...a 1 piece, 2 piece vitron and 2 piece rope type... I don't like the rope type and would need to remove the crank to use the one piece... I might as well change the seal while I have it apart but would like to use the 2 piece vitron seal. I would need to lift crank slightly to put this in but not remove it all together. Anyone know of a good source for the 2 piece vitron seal? |
#160
If you use either the one piece or two piece seals you will need to remove the serrations on the crankshaft in the seal area or it will eventually leak. Ask me how I know.
