Old 11-02-2023, 02:05 PM
TN68GTO's Avatar
TN68GTO TN68GTO is offline
Default 68 Power Antenna Help
The threads on my power antenna housing are trashed to the point that the threads look tapered. I when I put the antenna through the quarter panel I can't get the chrome nut to start on the housing because the threads are so bad. I've tried filing them but that hasn't helped. Is there a way to fix them or is the answer to find a new housing with better threads?
Jeramie
1968 GTO Convertible
1968 GTO Coupe, currently undergoing full frame off resto.
Old 11-02-2023, 03:57 PM
Cammer-6 Cammer-6 is offline
Maybe try a few drops of red loctite and carefully thread the nut on by hand.
If this doesnt work try fine copper wire wrapped same direction as threads.
This has worked for me to fix stripped threads but its a bandaid approach.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 11-02-2023, 04:39 PM
Scott Thelander's Avatar
coupe and convertible are different ....
but
you probably knew that ..............
Old 11-02-2023, 05:41 PM
I have used weedwhacker line to tighten up threads. For a fine thread, like that probably is, maybe a heavy fishing line.
EDIT Sorry, just realized that you don't have loose threads, you have ruined threads. One thing that I have had limited success with is taking a sharp triangle file and filing three grooves into the threads of the nut. It makes a fair dye/thread restorer.
Old 11-02-2023, 07:12 PM
TN68GTO's Avatar
Yes, sorry this is a coupe. I'm very hesitant to use a quick fix. I would love to find a permanent fix because this is a frame off restoration. My fear is that I need to try and find a better housing or worse yet spend the $$ for a new power antenna that has better threads.
Jeramie
