Old 11-28-2023, 09:31 PM
Dave M's Avatar
Dave M Dave M is offline
Default 71 Grill PONTIAC letters
I was looking at my recently restored 71 Formula and realized something was missing. I forgot to get the PONTIAC letters for the drivers side grill. No big deal. I’ll order some and install them. Except I can’t find them anywhere. I see 72. But no 70-71. Anyone know where I can get it? Thanks
Dave
Old 11-29-2023, 02:46 PM
unruhjonny's Avatar
really, they are not reproduced?
That's a surprise to me.
I am sure I have a spare or two...
I just looked in the printed Ames catalog, the price shows "inquire", but the part number is FB205
Weird, Classic Industries doesn't offer it (they are my go-to after Ames), neither does Year One (my go-to twenty-five years ago).
1970 Formula 400
Old 11-29-2023, 03:49 PM
unruhjonny's Avatar
ok, so I have dug a little further into this.
My master parts catalog shows some curious tidbits of information;
(print date November 1974)
485602 1967-1969/ALL - PONTIAC /SUP 9878859
481547 1970/ALL - PONTIAC
483933 1971/PONTIAC
487732 1972/PONTIAC EXC TRANS AM
487735 1973/PONTIAC
I included all 67-73 numbers so that you can see how they are originally listed.
Firstly, 1971 used the exact same grilles as 1970, and to the best of my understanding the emblem was called to be installed in the exact same location - so I am unclear why they are different part numbers.
I wanted to speak about the 1967-69 emblem, because it is available as a reproduction;
I bought one a short while back, except mine is not a reproduction, it is an NOS emblem that came with the parts ticket, in the older blue (not brown) GM box.
I grabbed one of my spare grilles which has the 70 emblem installed to compare the two:
Without removing the 70 emblem, the 67-69 emblem appears to be a near dead ringer;
The tiny grille locating studs behind the "T" appear to be in exactly the same spot;
The longer studs behind the "C" & "P" are almost perfectly in line with the '70 studs - but it appears as though the 67-69 (lets call it a 69 emblem from this point forward) has the stud behind the "C" set a little higher - the 69 emblem has the stud in line with the "-" in between the "A" & "C", while the 70 emblem has it set lower on the "C", with a tiny locating stud just above the "-".
On the other end of the emblems (at the "P"), the 69 emblem has two tiny locating studs, while the 70 has one - but the top 69 stud, is in the same spot as the one used on the 70 emblem.
The mounting stud (uses a nut) on the 69 emblem has a cast shoulder on it which may need to be trimmed back (a file should do the trick)...
Now, lets pause for a second;
The emblem itself is actually one half of the puzzle;
The other half is the little mounting brackets that the nuts sinch up against.
If I leave the brackets where they need to be on the 70 grille to mount the 70 emblem, but try to install the 69 emblem, it mounts almost perfectly with no modification in the correct spot.
I have tried to picture this for you...
here are the two beside each other:
Here is the 70 emblem held in place with the brackets:
Here is the 69 emblem held in place - with the 70 brackets where they are supposed to be:
The only obvious difference is the location where the "C" stud pokes up.
ID:	623996   Click image for larger version
ID:	623997   Click image for larger version
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 11-29-2023, 03:51 PM
unruhjonny's Avatar
here are close ups of the mounting and alignment studs of the 70 emblem:
ID:	623999   Click image for larger version
ID:	624000   Click image for larger version
1970 Formula 400
Old 11-29-2023, 03:53 PM
unruhjonny's Avatar
here are close ups of the 69 emblem on the 70/71 grille with the same brackets in place:
ID:	624002   Click image for larger version
ID:	624003   Click image for larger version
1970 Formula 400
Old 11-29-2023, 03:58 PM
unruhjonny's Avatar
also, incidentally, I have never known the 70 & 71 grille emblems to be differentiated - but maybe I just missed this factoid...
The NOS 69 emblem I have here has on the back a casted in number 9788859;
This 70 emblem has on the back a casted in number 480863
I hope this helps
And If you are interested in buying one of my spare emblems, I can see if I have the little brackets to go with it.
1970 Formula 400
Old 11-30-2023, 01:39 AM
Ramairnacho Ramairnacho is offline
Default 1970 pontiac emblem
Here is a pic of mine from 1970 grill emblem never removed
Old 11-30-2023, 01:01 PM
72projectbird's Avatar
I'll see if I have one. If I do, you're more than welcome to it.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-30-2023, 05:39 PM
Formulabruce's Avatar
On the parts catalog numbers, and this has been discussed on here in past. The reason there are two numbers is because one number is a " kit " for dealer or body shop. Other number is just the " bare emblem" which will match the number on the emblem itself. Kit has specific washers and the speed nuts.
" Long may we DRIVE !"
Old 12-01-2023, 01:01 PM
It’s been removed and reinstalled incorrectly. Too far down and too far to the left. Also the retaining brackets are installed incorrectly, look at the one behind the “C”.
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
The Following User Says Thank You to Singleton For This Useful Post:
Old 12-01-2023, 02:00 PM
Default Emblem
I have never touch this emblem.ans had car since I was 6 years old. I highly dought its ever been removed. But shoe us correct location sir. This is one on my esprit l65. Im.no expert still learning about my car
Old 12-01-2023, 03:36 PM
Nacho, the last pic that you posted has the correct emblem location, the one you show in post #7 isn’t. Comparing the two, it’s easy to see the difference in location and the orientation of the retaining brackets behind the emblem
ID:	624137   Click image for larger version
70 Formula 400/auto
Old 12-01-2023, 03:39 PM
File I have
70 Formula 400/auto
The Following 2 Users Say Thank You to Singleton For This Useful Post:
Old 12-01-2023, 04:04 PM
tdavidl's Avatar
tdavidl tdavidl is offline
damn you singleton....now i'm gonna have to check mine to make sure i put it back in the right spot 15 yrs ago lol.....
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
The Following 2 Users Say Thank You to tdavidl For This Useful Post:
Old 12-01-2023, 06:26 PM
unruhjonny's Avatar
lol
I was surprised when I saw very precise location/install instructions;
It really made sense once you put it in place with the correct brackets.
1970 Formula 400
Old 12-01-2023, 10:52 PM
Default Wmblem
Originally Posted by unruhjonny View Post
lol
We are always learning something new.
Old 12-05-2023, 01:24 AM
Dave M's Avatar
I hope this helps
Sure let me know how much you want. You can either DM me or email.
[email protected]
Thanks!!
Old 12-05-2023, 11:33 AM
unruhjonny's Avatar
Mine would be coming from Canada, so shipping alone might make it more expensive than getting from another member;
I would be happy to sell my spare, but need to (re)point out this post:
Seems like a deal that should be hard to pass up on!
1970 Formula 400
Old 12-05-2023, 01:08 PM
Dave M's Avatar
Good Point. I didn't see his comment. Thanks
The Following User Says Thank You to Dave M For This Useful Post:
Old 12-05-2023, 01:10 PM
Dave M's Avatar
Yes please. Let me know if you do have one and how much you want for it. Thanks!!
