I was looking at my recently restored 71 Formula and realized something was missing. I forgot to get the PONTIAC letters for the drivers side grill. No big deal. I’ll order some and install them. Except I can’t find them anywhere. I see 72. But no 70-71. Anyone know where I can get it? Thanks
Dave ![]() Sent from my iPhone using Tapatalk |
really, they are not reproduced?
That's a surprise to me. I am sure I have a spare or two... I just looked in the printed Ames catalog, the price shows "inquire", but the part number is FB205 Weird, Classic Industries doesn't offer it (they are my go-to after Ames), neither does Year One (my go-to twenty-five years ago).
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 11-29-2023 at 02:55 PM. |
ok, so I have dug a little further into this.
My master parts catalog shows some curious tidbits of information; (print date November 1974) Quote:
Firstly, 1971 used the exact same grilles as 1970, and to the best of my understanding the emblem was called to be installed in the exact same location - so I am unclear why they are different part numbers. I wanted to speak about the 1967-69 emblem, because it is available as a reproduction; I bought one a short while back, except mine is not a reproduction, it is an NOS emblem that came with the parts ticket, in the older blue (not brown) GM box. I grabbed one of my spare grilles which has the 70 emblem installed to compare the two: Without removing the 70 emblem, the 67-69 emblem appears to be a near dead ringer; The tiny grille locating studs behind the "T" appear to be in exactly the same spot; The longer studs behind the "C" & "P" are almost perfectly in line with the '70 studs - but it appears as though the 67-69 (lets call it a 69 emblem from this point forward) has the stud behind the "C" set a little higher - the 69 emblem has the stud in line with the "-" in between the "A" & "C", while the 70 emblem has it set lower on the "C", with a tiny locating stud just above the "-". On the other end of the emblems (at the "P"), the 69 emblem has two tiny locating studs, while the 70 has one - but the top 69 stud, is in the same spot as the one used on the 70 emblem. The mounting stud (uses a nut) on the 69 emblem has a cast shoulder on it which may need to be trimmed back (a file should do the trick)... Now, lets pause for a second; The emblem itself is actually one half of the puzzle; The other half is the little mounting brackets that the nuts sinch up against. If I leave the brackets where they need to be on the 70 grille to mount the 70 emblem, but try to install the 69 emblem, it mounts almost perfectly with no modification in the correct spot. I have tried to picture this for you... here are the two beside each other: Here is the 70 emblem held in place with the brackets: Here is the 69 emblem held in place - with the 70 brackets where they are supposed to be: The only obvious difference is the location where the "C" stud pokes up.
1970 Formula 400 Carousel Red paint on Black standard interior A no-engine, no-transmission, no-wheel option car. Quite likely one of few '70 Muncie three speed Formula 400's left. 1991 Grand Am: 14.4 @ 93.7mph (DA corrected) (retired DD, stock appearing) 2009 Cobalt SS: 13.9 @ 103mph (current DD; makes something north of 300hp & 350ft/lbs) Last edited by unruhjonny; 11-29-2023 at 03:59 PM. |
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
here are close ups of the mounting and alignment studs of the 70 emblem:
here are close ups of the 69 emblem on the 70/71 grille with the same brackets in place:
also, incidentally, I have never known the 70 & 71 grille emblems to be differentiated - but maybe I just missed this factoid...
The NOS 69 emblem I have here has on the back a casted in number 9788859; This 70 emblem has on the back a casted in number 480863 I hope this helps ![]() And If you are interested in buying one of my spare emblems, I can see if I have the little brackets to go with it.
Here is a pic of mine from 1970 grill emblem never removed
I'll see if I have one. If I do, you're more than welcome to it.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
| The Following User Says Thank You to 72projectbird For This Useful Post: | ||
On the parts catalog numbers, and this has been discussed on here in past. The reason there are two numbers is because one number is a " kit " for dealer or body shop. Other number is just the " bare emblem" which will match the number on the emblem itself. Kit has specific washers and the speed nuts.
" Long may we DRIVE !" |
It’s been removed and reinstalled incorrectly. Too far down and too far to the left. Also the retaining brackets are installed incorrectly, look at the one behind the “C”.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
| The Following User Says Thank You to Singleton For This Useful Post: | ||
I have never touch this emblem.ans had car since I was 6 years old. I highly dought its ever been removed. But shoe us correct location sir. This is one on my esprit l65. Im.no expert still learning about my car
Nacho, the last pic that you posted has the correct emblem location, the one you show in post #7 isn’t. Comparing the two, it’s easy to see the difference in location and the orientation of the retaining brackets behind the emblem
File I have
| The Following 2 Users Say Thank You to Singleton For This Useful Post: | ||
damn you singleton....now i'm gonna have to check mine to make sure i put it back in the right spot 15 yrs ago lol.....
| The Following 2 Users Say Thank You to tdavidl For This Useful Post: | ||
lol
I was surprised when I saw very precise location/install instructions; It really made sense once you put it in place with the correct brackets.
We are always learning something new.
Sure let me know how much you want. You can either DM me or email. [email protected] Thanks!! |
Mine would be coming from Canada, so shipping alone might make it more expensive than getting from another member;
I would be happy to sell my spare, but need to (re)point out this post: Seems like a deal that should be hard to pass up on!
Good Point. I didn't see his comment. Thanks
| The Following User Says Thank You to Dave M For This Useful Post: | ||
Yes please. Let me know if you do have one and how much you want for it. Thanks!!
