Old 12-24-2023, 06:56 PM
darbikrash darbikrash is offline
John,your thought on iron headed 10.25 engine on E 85?Do you think it can handle any boost on a street driver?Tom
I think an iron head with 10.25 CR with E-85 would be fine if boost is kept under 10 psi or so.
We’ll know more when we get to the dyno and see firsthand what the IAT numbers look like.
This design has a double pass through intercooler design which should keep IAT’s substantially lower than other designs. Lower IAT’s means less chance for detonation, and the full sequential port EFI means tight engine management.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 12-24-2023, 07:35 PM
KS circutguy's Avatar
Question
Wondering how you run a alternator-AC compressor"
Separate pulley?
Old 12-24-2023, 08:42 PM
Separate pulley?
Yes, separate 6 rib serpentine for accessories. The blower drive pulley is a dedicated 8 rib serpentine that has its own HD automatic belt tensioner. This allows you to change blower pulleys (and boost) without disturbing the accessories.
This also keeps the blower belt as sort as possible which helps eliminate slip.
I’ll post pics of the accessory drive as it progresses, but it will accommodate alternator, power steering, and optionally AC.
The Following User Says Thank You to darbikrash For This Useful Post:
Old 01-15-2024, 10:52 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Do you know about how far your accessory and blower drive assemblies will stick out from the front face of the engine? Early GTO’s are a little limited on space between the radiator and engine….
Also anyone know how reliable electric water pumps are on a street driven vehicle?
Thanks, and beautiful work!
Old 01-16-2024, 12:09 PM
The motor pictured elsewhere in this thread is going into my '65 GTO after the dyno pulls. I was able to measure all the clearances as my '65 has the same electric water pump and twin Spal electric fans.
The accessory pulley measures about 2.5" away from the back of the Spal fans- so plenty of clearance.
I've had the electric water pump in my '65 for about 6 years with no issues, they are rated for 3000 hours.
