Old 12-24-2023, 01:41 PM
darbikrash darbikrash is online now
Default New Pontiac project
We’ve closed out production of the Bathtub intakes, and unless a substantial demand pops up for more, these are sold out and I don’t foresee any more will be made.
Thanks to all who contributed to this project, espescially Tom S. without whose help the bathtub would not have been made.
This project gave me valuable contacts with pattern makers and a local foundry, who I have continued to work with.
I thought I would share a few pictures of a new project that is soon to be in production, a marque specific Pontiac supercharger. I realize forced induction may not be everyone’s cup of tea, but I do think there is a (small) market for a twin screw style supercharger compatible with low compression, smog headed engines- and will fit under the hood of most stock vehicles.
This blower is based on the Eaton TVS 2650 twin screw head unit, which is OEM for several current GM products and has a significant track record for durability in consumer street use.
I have signed a deal to receive completed and tested head units, and have engineered the necessary manifolds, risers, injector rails, inter cooler brick and lid, and a custom serpentine drive unit, all specific to the Pontiac block.
The unit can be configured to fit either early or late style heads, and has a lower total height that the stock intake/air cleaner than my 69 F body.
An awful lot of work went into this, and there is a lot going on “under the hood” which I can cover in future posts.
For now, here are a few pictures of the finished product:
Several options for injector placement, here the fuel rails, injectors and injector harnesses are all hidden underneath the blower in the valley. Injector placement is also available in the conventional location outboard of the risers pointing down, but this hidden arrangement is much cleaner.
Close up of the Pontiac arrowhead, you can see the machining detail and the quality of the tool paths.
Here are a few shots of the blower installed on the 455 dyno mule. It has unported 112 cc cast iron (4X) heads and 8.2 compression ratio and an OF 2 roller cam. Stock crank with Molnar rods.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Old 12-24-2023, 01:49 PM
KS circutguy's Avatar
Beautiful.
Nice work.
Old 12-24-2023, 01:50 PM
tom s tom s is offline
Finally!Cant wait to see it on the Westec dyno!Tom
Old 12-24-2023, 02:10 PM
72projectbird's Avatar
Holy Jesus!
I'm definitely interested
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-24-2023, 02:12 PM
nytrainer's Avatar
Me likey!
Old 12-24-2023, 02:20 PM
Verdoro 68's Avatar
Woah! Awesome work.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 12-24-2023, 02:38 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Very impressive! ETA?
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 12-24-2023, 02:50 PM
Over the top incredible setup.
Projected price point?
Old 12-24-2023, 03:21 PM
John,your thought on iron headed 10.25 engine on E 85?Do you think it can handle any boost on a street driver?Tom
Old 12-24-2023, 03:26 PM
chevymad chevymad is offline
That... is NICE! How bout a shaker top? lol
Old 12-24-2023, 04:23 PM
Stuart's Avatar
Stuart Stuart is offline
Very cool.
If you want exact layout dimensions for the arrowhead, I posted this image some years ago; it's from an internal Pontiac design manual from 1964 (I don't know if it was changed at all in subsequent years, like if that star in the middle was kept or deleted.)
Old 12-24-2023, 05:00 PM
hojs69's Avatar
hojs69 hojs69 is offline
Location: Pacific NW by way of Detroit, Tampa, San Diego
Very cool.
79 Trans Am WS6
71 Formula
72 Formula
71 Firebird
69 Firebird
Old 12-24-2023, 06:16 PM
wow, somebody picked up the ball and ran!
Old 12-24-2023, 06:37 PM
Very cool.
Thanks for that, I’ll compare those dimensions to what is on there now. A good friend of mine is a professional automotive stylist and he did the design of the lid. We went through many variations and landed on the version you see. I would not be at all surprised if the arrow is pretty close to the original- I know he did research during the design process.
I will definitely check though.
Here are a couple of the early iterations:
[/url
Old 12-24-2023, 06:48 PM
Still working on pricing. It will be comparable to an aftermarket kit for an LS- certainly not more.
We have two complete blowers with all parts machined on the 5 axis, one is the 455 which will be on the dyno soon. The other is going into a friend’s 1970 GTO with a stroked 400 for some real world street testing.
We are having the foundry make patterns now and they will make custom castings for the manifold risers as well as the lid. Once we get their numbers I can roll that into the final cost.
Figure 4-6 months for the first articles to be cast by the foundry and machined by us, then they will come out pretty fast. But if the Bathtub project taught us anything is never believe a foundry’s lead time estimates.
The Following User Says Thank You to darbikrash For This Useful Post:
Old 12-24-2023, 06:56 PM
I think an iron head with 10.25 CR with E-85 would be fine if boost is kept under 10 psi or so.
We’ll know more when we get to the dyno and see firsthand what the IAT numbers look like.
This design has a double pass through intercooler design which should keep IAT’s substantially lower than other designs. Lower IAT’s means less chance for detonation, and the full sequential port EFI means tight engine management.
Old 12-24-2023, 07:35 PM
Question
Wondering how you run a alternator-AC compressor"
Separate pulley?
Old 12-24-2023, 08:42 PM
Separate pulley?
Yes, separate 6 rib serpentine for accessories. The blower drive pulley is a dedicated 8 rib serpentine that has its own HD automatic belt tensioner. This allows you to change blower pulleys (and boost) without disturbing the accessories.
This also keeps the blower belt as sort as possible which helps eliminate slip.
I’ll post pics of the accessory drive as it progresses, but it will accommodate alternator, power steering, and optionally AC.
Old 12-24-2023, 09:15 PM
Excellent
Thanks.
Old 12-24-2023, 10:05 PM
Cool project!
