#301
What are the specs on that one? Always curious to see what youre cooking up.
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5 TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
#302
455,WT 69 block,6.8 rod 3 in main 4.21 stroke.SM heads OF.Tom
The Following 3 Users Say Thank You to tom s For This Useful Post: | ||
#303
A little info on the current project:
1955 Chieftain 2-dr Wagon - .30 over 428 (Thanks to Brewster for selling me the 428) - Muncie M20 4-speed - C4 front and rear suspension grafted onto wagon frame - Paint will be left as-is for now, but may change after up and running Last night, test fit the body back on the frame to check for fit and/or interferences. A couple areas of concern but nothing major. While body is on the frame, will measure and mark additional areas of firewall that need to be trimmed for clearance and for symmetry. Setback for the firewall will need to be in the neighborhood of 4. Also installed, with some modifications, the 57 Chevy brake/clutch pedal assembly and test fit the new tilt steering column to figure out the connection between it and the C4 intermediate shaft, which turned out to be fairly simple. A few additional build pics in the PY album: 55 Chieftain (https://forums.maxperformanceinc.com...p?albumid=2024) Tony
1998 GOLD Pontiac Firebird Formula HT, M6 1968 Pontiac LeMans Convertible 1968 Pontiac Lemans HT - Frame-off restomod with LS1 transplant 1955 Pontiac Chieftain - 2 Dr Wagon - Newest project 2008 Chevy Silverado 4X4 - Daily driver |
The Following 4 Users Say Thank You to MUCHMETAL For This Useful Post: | ||
#304
![]() Quote:
https://www.flickr.com/photos/197745168@N07/ "There's nothing more unsatisfying than watching an electric car go down the dragstrip." |
#305
I knew those Accel Super coils were good for something.
![]() Nice work.
#306
I never use it,owner of the run stand has it mounted on it.Tom
#307
What intake is that? The support from the heat cross over doesn't look familiar to me.
#308
It is an incredible 66 degrees and sunny here today in Dayton, OH Started and warmed-up the 62 Catalina today in the garage. Let it run about 1/2 hour. Miss the sound of the solid lifter Pontiac engine during the dreary months. Wanted to go out for a drive but still 1/4" of salt on all the roads here from the couple inches of snow we had just 2 days ago!
#309
Picked up this 389 a while back for my Suburban. Took the top end off to swap heads and check things out inside. Everything looked as expected except the water pump. With that stamped impeller and what looked to be .250 plus of impeller clearance the pump probably didn't move much water. Time to start digging through the stash and see if I can find an late 11 bolt impeller and get it to fit this early pump.
If it breaks. I didn't want it in the first place. _____________________________________________ 69 GTO \ 72 FIREBIRD \ 1/2 OF A 64 GTO \ 70 JAVELIN \ 52 FORD PU \ 51 GMC PU \ 29 FORD PU \ 85 ALFA ROMEO SPYDER \ A HANDFUL OF ODD DUCATI'S \ 88 S10 LT1 BLAZER & MY DAILY DRIVER 67 SUBURBAN. |
The Following User Says Thank You to VCho455 For This Useful Post: | ||
#310
Test fit lower control arm, took a little massaging to get back in with new bushings as expected. Had to spend the majority of the day in the yard spring cleaning, mainly those 80 trillion Sweet Gum monkey ball thingies- nastiest trees on the planet!
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
#311
The intake is a 1962-1963 421 SD NASCAR intake.I had Dave at SD rework the ports to match late heads,used a water Xover from a alu intake.Pretty much a RAIV-455HO intake for a AFB carb.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
#312
Started the car today for the first time in a couple months. I was happy it fired right up after gas finally made it to the carb.
Battery had run down before so I checked the voltage and heard "no Mike, the alternator is not working" inside my head. One of those good, bad, good, bad things. Hopefully it will be easy to figure out and correct. |
The Following User Says Thank You to Shiny For This Useful Post: | ||
#313
I knew there had to be something cool about that seemingly ordinary combo!
#314
![]() Quote:
![]() Its running great. Burned about 1/4 tank off then filled it up with some fresh non ethanol gas.
![]() 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. 63 LeMans- 69 400 w/ original transaxle. 2.69 gears. |
The Following 3 Users Say Thank You to 67drake For This Useful Post: | ||
#315
And then threw my new center link in.
The Following 2 Users Say Thank You to 67drake For This Useful Post: | ||
#316
[QUOTE=67drake;6489959]Record temperatures here in SW Wisconsin today.
Lookin' confident behind the wheel... 👍
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
The Following User Says Thank You to kingbuzzo For This Useful Post: | ||
#317
![]() Quote:
How'd he do with the Muncie? My son is still trying to figure out the 6 speed on the T/A. At the rate he's currently learning, I may need to start shopping for a clutch.
The Following User Says Thank You to Verdoro 68 For This Useful Post: | ||
#318
He did OK. Grew up riding dirt bikes, so familiar withthe idea behind feathering the clutch, but throw in an old original worn out shifter and it can be challenging. He was a little nervous about down shifting into reverse, but assured him that ain’t gonna happen unless he really tried.
#319
Replaced the throwout bearing.
1965 GTO 389 Tri-Power 4-Speed ![]() Johnny |
The Following User Says Thank You to ReelFun For This Useful Post: | ||
#320
Pulled the cover off the Formula opened the hood to see the empty engine bay.
Got some work to do before the new motor is ready
74 Formula Below motor destroyed last fall 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.061 @ 110.74 12.092 @ 112.43 12.128 @ 111.71 New motor 461 stroker Edelbrock 87 cc dport heads Performer RPM Same Ram Air manifolds, and quadrajet Results will be posted after the track |
Thread Tools | |
Display Modes | |
