#581
‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. ‘55 Catalina ‘62 Mercury Meteor-all original, bought new by my grandfather 71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs.-now my sons ride |
| The Following User Says Thank You to 67drake For This Useful Post: | ||
#582
Yeah, I see the plastic rib that you're talking about, you've got a good eye. Very hard to see the circle you drew due to my colorblindness.... I don't really see how the rotor terminal could have hit that since it's actually further away than the cap terminals. In other words, if the rotor was hitting the rib, it would have been hitting the terminals too. But, I don't know, maybe. It definitely hit something. Also, that rotor terminal is pretty thick and not easy to bend. I pressed on it pretty hard and it doesn't move. I'll have a new cap and rotor in a couple days. I'll have to take a very close look at them before I put it together. I may give DUI a call too and see what they have to say.
| The Following User Says Thank You to jhein For This Useful Post: | ||
#583
DUI says most likely the cap was not correctly installed and the engine was cranked. Must have happened at some point during the build process.
#584
Amazing it's been running so well with the rotor looking like that.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#585
When I install the new cap and rotor, I'll have to adjust the timing. I'll start by retarding it approximately the same amount as the bend and go from there.
#586
In the process of rebuilding the points type distributor for my 62. Installed the "composite" gear to be compatible with the roller cam. As this was an older distributor (from a 65 , 421, I had to drill the shaft to accommodate the roll pin.
My money talks to me-it usually says goodbye! |
#587
Fender reinstalled. Been futzing with this off and on for the last few days. Gaps are not perfect, but way better than before.
#588
I have to repair my leaking Quadrajet so I pulled it off and replaced with another 7040263 that I have. This new carb came from Quadrajet Power. I bought it last year and it's setup for this motor. I adjusted the idle mixture screws Gets 16" vacuum at 775 rpm. Not bad. I don't have my new cap and rotor yet but, I put it back together with the damaged ones so I could get the carb setup and so I could see where the timing was set so when I put in the new parts I know where to start. UPS will be here with the new parts later today so I'll do that tomorrow. Then I'll be back in business.
#589
72 Lemans sport 462 auto 75 Trans Am 4 speed 39k miles |
#590
Have a few chips on the car I wanted to get touched up, but the shop that painted the car sold to a collision chain and I can't find anyone with the brand of paint they used to paint the car. Took a hood scoop down to San Leandro Color to see if they could match it. She pulled out the old paint chip book to find the color codes. Kinda neat to see the slight difference in '68 and '69 Verdoro side by side. Of course mine was neither, but they were able to get something close that will work for the small chips I have to fill.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST Last edited by Verdoro 68; 06-01-2024 at 09:32 PM. |
#591
A local Porsche dealer has a cars and coffee event the first Saturday of every month so I took the opportunity to put a few miles on the Le Mans.
There was quite a bit of interest in the Tri-Power engine that a lot of people have never seen before. Had my guard dog on duty too.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following 5 Users Say Thank You to b-man For This Useful Post: | ||
#592
I've painted a couple of cars that color a 64 bonny and Todd Rehrs 63-LeMans. I used DuPont paint get the Nason it's cheaper in price. You'll love the results. GT |
#593
Bart, watch she doesn’t rip that door or radiator cradle off!! 😂
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
| The Following User Says Thank You to BILL BOWMAN1 For This Useful Post: | ||
#594
Picked up some faded PMD wheel centers at a Swap meet and inserted my custom centers.
#595
Oh I like that!
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
#596
Scheduled two friends to help install new front bumper this Saturday. We shall see.
#597
Went to a speciality car auction here - guy is trying to build the Barrett Jackson of the north...so cool - never been to one before. Lots of interesting stuff, bentleys, ferraris, shaguars, lotuseses, u name it...and of course our beloved pontipigs:
the ellusive 2_2! TTA! uggg LS...guy lost his shirt I never seen this vintage of toranado with the wrap-around (suicide) back window...bizarre!
#598
Put a few more things under the hood on the way to getting it running again.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
#599
NICE!
#600
I have to issue a correction. I didn't realize how much my idle speed changed when I adjusted the mixture screws. I had it at 775 rpm, after the idle mixture was adjusted, the vacuum did go up to 16", but the idle speed also went up to 1000 rpm. When I decreased the curb idle to 800 it went down to 15". Still pretty good.
