Old 05-28-2024, 08:20 PM
67drake's Avatar
67drake 67drake is online now
I'm not sure exactly what you looking at but if something looks wrong on the rotor, it's just lighting, shadows, etc. The only thing I found bent was the terminal on the rotor.
No, in the picture of the cap. I circled it. Looks like a chunk of plastic got bent or snapped off from the rotor. but like I said the picture is fuzzy, so maybe I’m seeing it wrong.
‘55 Catalina
  #582
Old 05-28-2024, 08:46 PM
jhein's Avatar
jhein jhein is offline
Sorry, I typed rotor when I meant cap.
Yeah, I see the plastic rib that you're talking about, you've got a good eye. Very hard to see the circle you drew due to my colorblindness....
I don't really see how the rotor terminal could have hit that since it's actually further away than the cap terminals. In other words, if the rotor was hitting the rib, it would have been hitting the terminals too. But, I don't know, maybe. It definitely hit something. Also, that rotor terminal is pretty thick and not easy to bend. I pressed on it pretty hard and it doesn't move. I'll have a new cap and rotor in a couple days. I'll have to take a very close look at them before I put it together. I may give DUI a call too and see what they have to say.
The Following User Says Thank You to jhein For This Useful Post:
  #583
Old 05-29-2024, 11:02 AM
jhein's Avatar
DUI says most likely the cap was not correctly installed and the engine was cranked. Must have happened at some point during the build process.
The Following 2 Users Say Thank You to jhein For This Useful Post:
  #584
Old 05-29-2024, 12:21 PM
Verdoro 68's Avatar
Amazing it's been running so well with the rotor looking like that.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #585
Old 05-29-2024, 02:45 PM
jhein's Avatar
No kidding. I think the reasons for that are that even though it was bent, it was very stable/solid in its new configuration and it appeared to be still making good enough approximation to the distributor terminals.
When I install the new cap and rotor, I'll have to adjust the timing. I'll start by retarding it approximately the same amount as the bend and go from there.
  #586
Old 05-29-2024, 04:11 PM
carcrazy carcrazy is offline
In the process of rebuilding the points type distributor for my 62. Installed the "composite" gear to be compatible with the roller cam. As this was an older distributor (from a 65 , 421, I had to drill the shaft to accommodate the roll pin.
  #587
Old 05-29-2024, 06:02 PM
Verdoro 68's Avatar
Fender reinstalled. Been futzing with this off and on for the last few days. Gaps are not perfect, but way better than before.
Ken
'74 Ventura 350
'69 AMC Javelin SST
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
  #588
Old 05-30-2024, 06:53 PM
jhein's Avatar
I have to repair my leaking Quadrajet so I pulled it off and replaced with another 7040263 that I have. This new carb came from Quadrajet Power. I bought it last year and it's setup for this motor. I adjusted the idle mixture screws Gets 16" vacuum at 775 rpm. Not bad. I don't have my new cap and rotor yet but, I put it back together with the damaged ones so I could get the carb setup and so I could see where the timing was set so when I put in the new parts I know where to start. UPS will be here with the new parts later today so I'll do that tomorrow. Then I'll be back in business.
  #589
Old 05-30-2024, 07:39 PM
Skidmark's Avatar
Skidmark Skidmark is offline
That's awesome. My carb from them should be here end of summer. Getting a 76 stick carb to replace the original Odd ball 75 q jet. Saving original for next owner.
72 Lemans sport 462 auto
75 Trans Am 4 speed 39k miles
  #590
Old 06-01-2024, 09:26 PM
Verdoro 68's Avatar
Have a few chips on the car I wanted to get touched up, but the shop that painted the car sold to a collision chain and I can't find anyone with the brand of paint they used to paint the car. Took a hood scoop down to San Leandro Color to see if they could match it. She pulled out the old paint chip book to find the color codes. Kinda neat to see the slight difference in '68 and '69 Verdoro side by side. Of course mine was neither, but they were able to get something close that will work for the small chips I have to fill.
ID:	634582   Click image for larger version
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #591
Old 06-01-2024, 10:31 PM
A local Porsche dealer has a cars and coffee event the first Saturday of every month so I took the opportunity to put a few miles on the Le Mans.
There was quite a bit of interest in the Tri-Power engine that a lot of people have never seen before.
Had my guard dog on duty too.
ID:	634590   Click image for larger version
ID:	634591   Click image for larger version
ID:	634592   Click image for larger version
ID:	634593   Click image for larger version
The Following 5 Users Say Thank You to b-man For This Useful Post:
  #592
Old 06-02-2024, 11:02 PM
blueghoast's Avatar
That is a beautiful color,
I've painted a couple of cars that color a 64 bonny and Todd Rehrs
63-LeMans. I used DuPont paint get the Nason it's cheaper in price.
You'll love the results.
GT
  #593
Old 06-03-2024, 06:26 AM
BILL BOWMAN1's Avatar
Bart, watch she doesn’t rip that door or radiator cradle off!! 😂
The Following User Says Thank You to BILL BOWMAN1 For This Useful Post:
  #594
Old 06-03-2024, 11:34 AM
Tempest's Avatar
Tempest Tempest is offline
Picked up some faded PMD wheel centers at a Swap meet and inserted my custom centers.
Name:	PMD centers.jpg
ID:	634671   Click image for larger version
Name:	5 centers done.jpg
The Following 2 Users Say Thank You to Tempest For This Useful Post:
  #595
Old 06-03-2024, 11:57 AM
Oh I like that!
Old 06-03-2024, 12:52 PM
Scheduled two friends to help install new front bumper this Saturday. We shall see.
  #597
Old 06-03-2024, 01:29 PM
Went to a speciality car auction here - guy is trying to build the Barrett Jackson of the north...so cool - never been to one before. Lots of interesting stuff, bentleys, ferraris, shaguars, lotuseses, u name it...and of course our beloved pontipigs:
the ellusive 2_2!
TTA!
uggg LS...guy lost his shirt
I never seen this vintage of toranado with the wrap-around (suicide) back window...bizarre!
The Following 3 Users Say Thank You to kingbuzzo For This Useful Post:
  #598
Old 06-03-2024, 02:55 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Put a few more things under the hood on the way to getting it running again.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
The Following 4 Users Say Thank You to TheSilverBuick For This Useful Post:
  #599
Old 06-03-2024, 03:56 PM
johnta1 johnta1 is online now
NICE!
  #600
Old 06-04-2024, 01:35 PM
jhein's Avatar
I have to issue a correction. I didn't realize how much my idle speed changed when I adjusted the mixture screws. I had it at 775 rpm, after the idle mixture was adjusted, the vacuum did go up to 16", but the idle speed also went up to 1000 rpm. When I decreased the curb idle to 800 it went down to 15". Still pretty good.
