Old 07-15-2024, 04:50 PM
slowbird's Avatar
slowbird slowbird is offline
10.25 isn't really low. Run the cam you have and enjoy. I would run a T2 intake with spacer though
The Following User Says Thank You to slowbird For This Useful Post:
Old 07-15-2024, 06:38 PM
ponjohn's Avatar
ponjohn ponjohn is offline
310CFM AND 242/248 cam will get you there.
The Following User Says Thank You to ponjohn For This Useful Post:
Old 07-15-2024, 09:23 PM
64gp4spd 64gp4spd is offline
Hi, I have a similar combination in a 64 GP with 5 speed TKX.
463 with Kauffman 310cfm heads 11to 1 compression, T2 intake with
1 inch spacer and Holley 950 HP. Running OF Cam on 112 LSA with 1.65
rockers. Absolutely love this combination.
Rich
1964 Pontiac Grand Prix Originally 389-4Barrel 4 Speed Manual.
Currently 463, Kauffman 310CFM Heads, 11:1 Compression, OF Cam,
Holley 950HP with Proform Base, Torker II with 1 inch spacer.
Mad Dog 1 3/4 Headers, TKX 5 Speed, Center Force DF Clutch, 4:10 Posi.
The Following User Says Thank You to 64gp4spd For This Useful Post:
Old 07-16-2024, 02:19 AM
blueghoast's Avatar
I agree with slow bird and tom s,
GT
Old 07-16-2024, 06:28 AM
Originally Posted by grivera View Post
Thanks - does the lower compression work better with the 110 LSA vs the 113 in my HR242 cam?
The 113 is just going to push the power band a little higher and spread the curve out. Not a bad thing. The bonus is smoother idle and more vacuum. Should run brakes fine.
My 242/248 was also on a 110 and it worked brakes marginally, I added an extra vacuum canister and drove it like that for nearly 25 years.
Dad's engine with the bigger 254/262 on a 110 didnt run brakes that well. He used a electric pump for a while but eventually switched over to hydroboost.
https://youtu.be/XqEydRRRwqE
Old 07-16-2024, 06:35 AM
Another is the 455 I built for a member here. It is 9.98:1 compression and I used Paul's custom spec'd 239/243 @050 with a 112 LSA. It is also over 600 lift. That engine was built to appear stock. Stock aluminum intake q-jet RA manifolds etc....and made 507/571 on the dyno Paul uses with a really nice flat torque curve. That car drives like a stocker with a nice snug-ish converter and 3.42's and runs the power brakes and AC. A very nice well manored driver that should go into the 11's.
Old 07-16-2024, 09:05 AM
ta man ta man is offline
That would be ideal - Is the OF designed with headers in mind? Also, what is your combo’s compression and what carb and spacer are you using?
My old combo was 10.25 to 1 for compression with a 950 Holley HP torker 2 and a one inch spacer
The Following User Says Thank You to ta man For This Useful Post:
Old 07-16-2024, 09:56 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Run what you have Will!!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
The Following User Says Thank You to OCMDGTO For This Useful Post:
Old 07-16-2024, 11:40 AM
grivera's Avatar
grivera grivera is offline
Is my Holley 850 Double Pumper 4781-5 up to the task?
Will Rivera
Old 07-16-2024, 11:51 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
All day.
The Following 3 Users Say Thank You to PunchT37 For This Useful Post:
Old 07-16-2024, 03:30 PM
Lee's Avatar
Lee Lee is offline
I was running 11.5's with a 231/239 HFT and iron D-ports, street trim, over 20 years ago. That was with a Torker II, no spacer, and a 4779 750 DP Holley.
The bigger the intake duration, the more stall you'll need to get a decent launch. I would NOT use more intake duration than what the OF uses.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
The Following 3 Users Say Thank You to Lee For This Useful Post:
Old 07-16-2024, 05:21 PM
Steve C. Steve C. is offline
"I was running 11.5's with a 231/239 HFT and iron D-ports, street trim, over 20 years ago"
Pssssst... Lee don't dare tell what LSA it had. Don't upset the troops
Old information here:
Old 07-16-2024, 05:23 PM
besserspat besserspat is offline
I know guys with 502 and 540 BBC with 700 lift HR cams running 11.5 s ....🤣
Peter
The Following User Says Thank You to besserspat For This Useful Post:
Old 07-16-2024, 07:51 PM
Yeah I can say that about any brand really. Most guys don't know how to tune, set up a car correctly, or even drive for that matter. There are plenty of pontiacs around here that don't run for chit too.
Old 07-16-2024, 08:05 PM
grivera's Avatar
Didn’t know this - thanks.
FJ- is this a factor with the 454 you mentioned?
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 07-16-2024, 08:11 PM
Nope, I ran a tight Continental P2 converter in it that would flash right at 32-3300 at the track with a nice little wheelie and go 1.59 60 foot times. Engine made peak torque at 4400 but didn't matter, even down where the converter flashed it was still enough torque to yank the tires. Converter drove really snug on the street too, one of the best I ever had in the car.
Certainly could have went quicker with more stall converter but there is this thing called compromise. I like nice street manors so I give up a little
Old 07-16-2024, 09:02 PM
grivera's Avatar
Awesome- thanks
Will Rivera
  #38
Old 07-16-2024, 10:09 PM
grivera's Avatar
Rich
Have you taken that beast to the track? What’s it run? How about power brakes/vacuum?
Is the Torker 2 port matched to the 310 heads? Any issues there?
Will Rivera
  #39
Old 07-17-2024, 02:17 AM
Dragncar Dragncar is offline
You will be fine with what you have.
Brakes ? I am running a 265-274 112 cam in a 461 and it runs the brakes OK.
  #40
Old 07-17-2024, 02:22 AM
Peter
My engine has only been down the track 4 times and not made a full pass yet.
Testing. Making sure it stops and does not leak ect.
But the best pass was a 11.50 while getting off the gas just past the 1/8 mile mark.
Took off at 3000 RPM and went through the lights @ only 92 MPH.
Sad deal if you can,t get a 540 BBC below 11.50 !
