Will 3” headers for a 1973 400 block, also fit a 1964 389 block?
3 in what?
3” headers?
Is that the collector size because it sure can’t be the primary pipe size. All Pontiac blocks are dimensionally the same externally, the same physical size. If both have D-port heads (used on 99.99999% of Pontiac engines) which is highly likely then yes of course. Pontiac heads can be interchanged onto any Pontiac block. And please let’s not bring up the short-deck 301 and 265 blocks that 99.99999999% of us don’t want or use.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
This is my first Pontiac, so please forgive my lack of knowledge on the subject. Thanks. Last edited by Badgoat64; 07-18-2024 at 09:39 PM. Reason: Info |
If your Edelbrock heads have round exhaust ports then the 389 would have to have round port heads too for the headers to work. 389 engines never came with round port heads.
Edelbrock in recent years did produce D-port heads (two center exhaust ports look like the letter D back to back) so it’s possible your headers from your 461 would work. As long as the type of head as in exhaust port style match your headers will work. Keep in mind that round port Edelbrock heads will have a flat on the exhaust port floor at the port exit flange but they’re still considered round port.
http://forums.maxperformanceinc.com/...d.php?t=636309
From the Street forum Tech Thread Archive, round port and D-port head differences. The differences between them are pretty easy to spot.
