Old 07-21-2024, 04:36 PM
64srule's Avatar
64srule 64srule is offline
Default my latest 64 GTO!
Picked up this 64 GTO. PHS Docs, 389 tri-power,4 spd, 3:90 safe-t-track. It has some nice options: Tach,sport wheel covers, console,ps,sport steering wheel(unfortunately modified),padded dash. Original seats/panels have been changed to black at some point.
ID:	637165   Click image for larger version
ID:	637166   Click image for larger version
ID:	637167   Click image for larger version
The Following 10 Users Say Thank You to 64srule For This Useful Post:
Old 07-21-2024, 05:29 PM
Nice car!
Add some period-correct white wall or redline tires and original valve covers and it’s even better.
Too bad about someone thinking drilling holes and it looks like painting the rim black would be an improvement. Maybe a skilled welder could close up those holes being extra careful near the plastic rim, then someone could smooth the welds and restore the finish. You could then carefully remove the black paint.
Still a stunning example with the best performance options anyone could hope for.
Old 07-21-2024, 05:59 PM
carcrazy carcrazy is offline
Nice score....looks like a lot of fun!
The Following User Says Thank You to carcrazy For This Useful Post:
Old 07-22-2024, 02:58 PM
JSchmitz's Avatar
JSchmitz JSchmitz is online now
Nice car!
Is a shame that someone "improved" the best looking steering wheel ever made. I think I could TIG weld those shut with plugs and restore it.
Old 07-22-2024, 03:02 PM
KS circutguy's Avatar
Put a set of 3.42's in it.
You'll be happy you did.
Engine will thank you as well.
The Following User Says Thank You to KS circutguy For This Useful Post:
Old 07-22-2024, 04:09 PM
77 TRASHCAN's Avatar
I wonder if there's a stock valvetrain under those chrome valve covers???
Shut it off
Shut it off
Old 07-22-2024, 04:27 PM
People put different valve covers on strictly for looks 99% of the time.
1964 GTO heads would be unlikely candidates for screw-in studs, roller rockers and a stud girdle thereby requiring tall valve covers at least in my mind.
I have roller rockers and screw-in studs on my 1964 GTO heads with stock valve covers and a slightly thicker 5/16” gasket and that’s it. The vast majority of 1964 GTOs have just the original press-in rocker studs and original stamped steel 1.5:1 rockers you can bet.
Old 07-23-2024, 12:16 AM
64srule's Avatar
no, its has roller rockers on it..i would probably prefer stock valve covers but i am told they won't clear..
Old 07-23-2024, 12:20 AM
64srule's Avatar
I will check to see what it has..hopefully i can get stock covers to work!
Old 07-23-2024, 12:21 AM
64srule's Avatar
Originally Posted by JSchmitz View Post
Nice car!
I was thinking about doing the same thing!
Old 07-23-2024, 12:37 AM
Lightbulb
If the stock 1964 valve covers don’t want to fit your points of interference are most likely the polylock nuts. You can buy shorter ones or trim yours down on the bottom using a lathe.
In the post linked below there’s a couple of pictures of what my builder did to make my roller rockers fit under the stock covers:
https://forums.maxperformanceinc.com...&postcount=132
One more thing to consider would be to see if the rockers are high quality cast stainless steel or aluminum extrusions or just cheap cast aluminum ones. A lot of people use the Comp roller tip rockers that still have the pivot ball (they’re known for galling and turning blue from heat due to poor fit) which really aren’t any better than stock rockers and sometimes not as good. Inspect them no matter what type for cracking or defects such as the axle for the roller tip coming loose.
If you’re really wanting to run stock covers then perhaps replace them with stock rockers if that makes sense so long as they’re compatible with your engine build.
Old 07-23-2024, 11:10 AM
Originally Posted by 64srule View Post
Picked up this 64 GTO. PHS Docs.
What were the original colors - was it special paint Jubilee/Anniversary Gold ?
Does your PHS doc tell if it was M20 or M21 with the 3.90 ?
Fantastic Car
Heavy congrats to you
Old 07-23-2024, 02:19 PM
64srule's Avatar
Fantastic Car
Thanks for the compliment!
Its Saddle Bronze paint code S with light saddle interior..
its a code 9 trans m21 close ratio. engine has the 9 stamp as well
other options of note:
Metallic brake linings
Hd radiator
rear seat speaker
seat belts/floor mats
soft ray windshield
outside mirror
back up lamps
windshield washer/2 speed wiper
console
safe-t -track rear
red stripe tires
tachometer
Old 07-25-2024, 02:42 PM
geeteeohguy's Avatar
3.42's never came in an 8.2 ten bolt. the best the OP could do would be to install a set of 3.55's or 3.36's. But with the stock M-21, why? If I were him, I'd enjoy the car as is, at least for now. It's a beaut!
Jeff
Old 07-26-2024, 12:59 AM
Whoever ordered that car new was a badass .
Those guys are my heroes .
