#41
Not sure what to make of that. There is a post from him somewhere here where he mentions that. Back when he was doing a lot of Pontiac stuff he had a 459 CNC program for HPs.
In those days he had that Pro Port pump gas engine near 1000HP, Mikes E heads that made more power than your Barton High Ports with a like build, They went 414cfm, highest I know of and were not even flowed the last 2 times he worked on them. And that set of High Ports of Giro,s that inspired Mike to go with Marcella High Ports. Giros had the valves in stock location and Mike told me himself he thought John could get 480cfm with the valves moved around. Then there were the 502cfm @ .850 lift Tigers he did. For awhile it sure seemed like one guy had the best Pontiac E head, Pro Port, High Port and Tiger head. All done with welding, no stinking epoxy to leak later. Not sure I would doubt anything he has done. Who bought Giros top end with Mikes BOP. And whatever happened to Giro ? That guy was a blast. |
#42
You can believe what you want but I will still bet money he didn't get that cfm. Not without moving valves which he never did. I am very familiar with HP heads and what they are capable of. Find that post where he says that. Also I talked to Mike and Giro quite a bit back then and seen the heads.
#43
I've worked on John M's 460 cfm Hi-ports. I'm sure they'll make a ton of power but weren't a whole bunch different than another pair of Hi-ports we were working on that made record power. Those latter Hi-ports flowed less than 460 cfm.
Giro is doing well and working on a first Gen Firebird to put his Marcella/Brown bullet in. |
#44
Wilcox used to claim some big numbers from E-heads. Quote:
Not sure how you compare those two builds. Wasn't Mike's like 70 CID bigger? I thought Mike inspired Giro to go with Hi-ports... But could be wrong |
#45
![]() 70ci, more compression, dry sump to name a few. |
#46
Boy how time flies. This was over 10 years ago. What I have is 481 ci. Also Barry's dyno produced some real /not funny numbers.
Stan
#47
For a Ponti head newb like me that reads a thread like this...
What's the most a High Port cfm has shown without moving the valve? Is the Tiger 2 the newest version or is there something coming out after the new foundry team up? What is the Tiger 2 rough max cfm without valve moved? Everyone still agree cfm x2 is potential power for an engine on gas? That dyno chart looks higher than that if they're mid 450cfm heads. Thanks
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
#48
John's head were 466 so ► 1134 / 466 = 2.43348 I have seen dyno sheets for other engines around 2.5. Calvin Hill got 420 cfm from KRE HP with a 2.20" intake valve. Stan
#49
https://forums.maxperformanceinc.com...54#post5689654 I also found one of my old posts where I mention he has a CNC program that went 459cfm. So he had to have told me that. |
#50
It took 486 cfm@28” to make that 1132 hp from the dyno sheet in post 46.
#52
Those heads flowed 20cfm less than that. Those cfm to hp equations aren't very good at all imo.
#53
Remember that the head flow cfm numbers are @ 28" of water.A running engine sees much different and varying depression through the RPM range. The easiest way to see this is looking at a dyno sheet for an engine that has a 750 cfm carb rated v@ 1.5" hg (which is smaller than needed) and the dyno sheets shows measured SCFM at a value greater than that. Stan PS Let me add that while people look at dyno sheets for fuel lb/hr and BSFC what most dyno sheets don't show is BSAC.
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 10-18-2023 at 01:44 PM. |
#54
The same guys E heads beat that @ 414cfm.
#55
How do you know there is only one set of Marcellas High Ports out there. I mean, I do not know for a fact that there is, but I believe Scott Brown owns the CNC programs. If the man says he did not move the valve why would you doubt him ? Not sure why its so hard to believe. Mikes E heads went 414cfm. Thats 134cfm over as cast (280cfm) High Ports as cast 330cfm. Johns HPs 459cfm. A difference of 129 cfm. Thats a little less that his difference with E heads. Seems reasonable to me. Looking at some of those old ,great threads maybe you have a old ax to grind ? |
#56
This also is a case of don't always just look at the cfm. That set of heads was tailored for Mikes engine. That I can remember as John kept working on the heads he was adjusting the CSA for Mike's ci and RPM.
Stan
#57
No matter what you want to believe Marcella HP heads haven't out ran a single head yet unless you race flow benches, which I don't. |
| The Following User Says Thank You to slowbird For This Useful Post: | ||
#58
Old post, but butlers site has downsized yet again only offering the 430-440 cfm head on their site. However you can still get the “big port” version from BES. No clue yet how big the big port is but I will know.
#59
Nice please any info you might get on the heads
#60
