Old 10-14-2023, 03:14 AM
Dragncar Dragncar is offline
Originally Posted by slowbird View Post
I'm willing to bet he didn't actually get that
Not sure what to make of that. There is a post from him somewhere here where he mentions that. Back when he was doing a lot of Pontiac stuff he had a 459 CNC program for HPs.
In those days he had that Pro Port pump gas engine near 1000HP, Mikes E heads that made more power than your Barton High Ports with a like build, They went 414cfm, highest I know of and were not even flowed the last 2 times he worked on them.
And that set of High Ports of Giro,s that inspired Mike to go with Marcella High Ports.
Giros had the valves in stock location and Mike told me himself he thought John could get 480cfm with the valves moved around.
Then there were the 502cfm @ .850 lift Tigers he did.
For awhile it sure seemed like one guy had the best Pontiac E head, Pro Port, High Port and Tiger head. All done with welding, no stinking epoxy to leak later.
Not sure I would doubt anything he has done.
Who bought Giros top end with Mikes BOP. And whatever happened to Giro ?
That guy was a blast.
  #42
Old 10-14-2023, 07:08 AM
slowbird's Avatar
slowbird slowbird is offline
You can believe what you want but I will still bet money he didn't get that cfm. Not without moving valves which he never did. I am very familiar with HP heads and what they are capable of. Find that post where he says that. Also I talked to Mike and Giro quite a bit back then and seen the heads.
  #43
Old 10-14-2023, 09:51 AM
PAUL K's Avatar
PAUL K PAUL K is online now
I've worked on John M's 460 cfm Hi-ports. I'm sure they'll make a ton of power but weren't a whole bunch different than another pair of Hi-ports we were working on that made record power. Those latter Hi-ports flowed less than 460 cfm.
Giro is doing well and working on a first Gen Firebird to put his Marcella/Brown bullet in.
Go fast, see Elvis!
  #44
Old 10-14-2023, 10:16 AM
PAUL K's Avatar
Any idea how many Marcella Hi-ports are out there?
Wilcox used to claim some big numbers from E-heads.
Didn't Marcella's E-heads outpower his Pro-ports?
Mikes E heads that made more power than your Barton High Ports with a like build...
Not sure how you compare those two builds. Wasn't Mike's like 70 CID bigger?
I thought Mike inspired Giro to go with Hi-ports... But could be wrong
Go fast, see Elvis!
  #45
Old 10-14-2023, 11:07 AM
slowbird's Avatar
Lol ya the two engines are very comparable
70ci, more compression, dry sump to name a few.
  #46
Old 10-14-2023, 11:22 AM
Stan Weiss's Avatar
Boy how time flies. This was over 10 years ago. What I have is 481 ci. Also Barry's dyno produced some real /not funny numbers.
Stan
Pontiac Pump Gas List
  #47
Old 10-16-2023, 12:54 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
For a Ponti head newb like me that reads a thread like this...
What's the most a High Port cfm has shown without moving the valve?
Is the Tiger 2 the newest version or is there something coming out after the new foundry team up?
What is the Tiger 2 rough max cfm without valve moved?
Everyone still agree cfm x2 is potential power for an engine on gas? That dyno chart looks higher than that if they're mid 450cfm heads.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct @ 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline
  #48
Old 10-16-2023, 01:16 PM
Stan Weiss's Avatar
I like to use 2.2 but any number is just a very rough guess.
John's head were 466 so ► 1134 / 466 = 2.43348 I have seen dyno sheets for other engines around 2.5.
Calvin Hill got 420 cfm from KRE HP with a 2.20" intake valve.
Stan
  #49
Old 10-18-2023, 01:07 AM
Took me a bit. If he says it, I believe it.
https://forums.maxperformanceinc.com...54#post5689654
I also found one of my old posts where I mention he has a CNC program that went 459cfm. So he had to have told me that.
Name:	Screenshot 2023-10-17 at 21-52-32 Who is running the BOP intake - Page 2 - PY Online Forums - Br.jpg
  #50
Old 10-18-2023, 08:30 AM
slowbird's Avatar
They don't flow that without moving things, none of it matters because there is only 1 set of Marcella HP heads out there and they won't make the power a 460cfm head should.
  #51
Old 10-18-2023, 09:44 AM
It took 486 cfm@28” to make that 1132 hp from the dyno sheet in post 46.
  #52
Old 10-18-2023, 11:47 AM
slowbird's Avatar
Those heads flowed 20cfm less than that. Those cfm to hp equations aren't very good at all imo.
  #53
Old 10-18-2023, 01:29 PM
Stan Weiss's Avatar
Brian,
Remember that the head flow cfm numbers are @ 28" of water.A running engine sees much different and varying depression through the RPM range. The easiest way to see this is looking at a dyno sheet for an engine that has a 750 cfm carb rated v@ 1.5" hg (which is smaller than needed) and the dyno sheets shows measured SCFM at a value greater than that.
Stan
PS Let me add that while people look at dyno sheets for fuel lb/hr and BSFC what most dyno sheets don't show is BSAC.
  #54
Old 10-19-2023, 03:32 AM
The same guys E heads beat that @ 414cfm.
  #55
Old 10-19-2023, 03:42 AM
Why in the world would you doubt that guy ? Because your guy could not beat it ?
How do you know there is only one set of Marcellas High Ports out there. I mean, I do not know for a fact that there is, but I believe Scott Brown owns the CNC programs.
If the man says he did not move the valve why would you doubt him ?
Not sure why its so hard to believe.
Mikes E heads went 414cfm.
Thats 134cfm over as cast (280cfm)
High Ports as cast 330cfm.
Johns HPs 459cfm.
A difference of 129 cfm.
Thats a little less that his difference with E heads.
Seems reasonable to me.
Looking at some of those old ,great threads maybe you have a old ax to grind ?
  #56
Old 10-19-2023, 09:55 AM
Stan Weiss's Avatar
This also is a case of don't always just look at the cfm. That set of heads was tailored for Mikes engine. That I can remember as John kept working on the heads he was adjusting the CSA for Mike's ci and RPM.
Stan
  #57
Old 10-19-2023, 01:47 PM
slowbird's Avatar
Johns HPs 459cfm.
Because I don't believe everything I read. I know someone that deals with Scott Brown alot. I know Dan got about same cfm from wide port eheads, I know Dan's pp head flowed more than Marcella pp head, I know that Dan spent a LOT of time over 8yrs with my HP heads.
No matter what you want to believe Marcella HP heads haven't out ran a single head yet unless you race flow benches, which I don't.
The Following User Says Thank You to slowbird For This Useful Post:
  #58
Old 09-13-2024, 09:17 PM
Matt1970gto Matt1970gto is offline
Brian,
I seem to remember when this first came out that there was going to be a 450 cfm and 480 cfm.
Looking at Butler's web site it looks like they have downsized them.
Stan
Old post, but butlers site has downsized yet again only offering the 430-440 cfm head on their site. However you can still get the “big port” version from BES. No clue yet how big the big port is but I will know.
  #59
Old 09-13-2024, 10:19 PM
slowbird's Avatar
Nice please any info you might get on the heads
  #60
Old 09-13-2024, 11:41 PM
Brian,
Stan
Will do, will probably be next Friday before I get to talk to them again but I plan to ask just how big this set is going to be.,
