Old 09-23-2024, 02:42 PM
Default Source for good hose clamps
So all the hose clamps(heater hose radiator) at Oreily are a bilingual package and made in China.
Anyone have a source for good USA clamps
Old 09-23-2024, 02:43 PM
sdbob sdbob is online now
Cant help other than saying I've kept a lot of the old aeroseal clamps.
Old 09-23-2024, 02:46 PM
SRR's Avatar
SRR SRR is offline
ACE hardware has SS hose clamps.
― Calvin Coolidge
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Fairly certain they’re not USA made but, OE BMW hose clamps are quite good, at least the ones on my E36 are.
Solid band and stout screw section. IIRC they’re all “narrow”, the band, like 5/16” wide maybe. Maybe something to look into, which is what I was when it comes time to stock up.
Here’s an example…
https://www.ecstuning.com/b-genuine-...l/07129952113/
costs too much
The Following User Says Thank You to rolling money pits For This Useful Post:
Old 09-23-2024, 03:18 PM
peters23 peters23 is offline
Rock Auto carries the Gates hose clamps, which are US made.
The Following 2 Users Say Thank You to peters23 For This Useful Post:
Old 09-23-2024, 05:25 PM
limejudge69's Avatar
Breeze clamps are some of fhe best and are used a lot in the aviation world. Try Aircraft Spruce. They stock most any size, the quality is good and pricing is reasonable.
The Following 3 Users Say Thank You to limejudge69 For This Useful Post:
Old 09-23-2024, 05:42 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Avoid the clamps from Harbor Freight.
It amazes me folks are making and selling product that is purchased before it's thrown out. Who'd of thunk there is a market for disposable garbage.
Go fast, see Elvis!
Old 09-23-2024, 07:32 PM
Bermuda Blue Bermuda Blue is offline
Last time I bought hose clamps from McMaster they were high quality and US made.
https://www.mcmaster.com/products/ho.../hose-clamps~/
The Following 2 Users Say Thank You to Bermuda Blue For This Useful Post:
Old 09-23-2024, 11:22 PM
Breeze clamps will always have aircraft parts prices. We used a buttload of them in overhauls. Breeze clamps are the best, IMO. If you purchase the thumb screw variety be sure to find your local Snap-On guy for the 1/4” drive socket to install them.
Dr. Thomas Sowell
The Following User Says Thank You to hurryinhoosier62 For This Useful Post:
Old 09-23-2024, 11:42 PM
mgarblik mgarblik is offline
Here is some good information if you have 16 minutes to kill. https://www.youtube.com/watch?v=jtMPq2lG-8U
Old 09-24-2024, 12:51 AM
Schurkey Schurkey is offline
I have a love/hate relationship with Oetiker "Stepless" RE-USABLE screw clamps. (NOT the cheaper and more-common single-use "ear" clamps.) IF you can get them to fit your application, they're WONDERFUL. Thin, for high contact pressure (PSI) without squeezing the hose so bad it cold-flows. There's a trademark "Green" coil spring on the tension screw for constant torque in varying temperature. And "shielded" in that there's no worm-gear openings for the hose to cold-flow through. But where I was using them--primarily on silicone hump-hoses, the wall thickness variation of the hose was so great we needed to stock several sizes of Oetiker clamps to do what should have been identical jobs. In other words, the clamp range of the Oetiker design was so limited that it made assembly difficult. (Or, conversely, the uniformity of the hump-hoses we used was so poor that they were often incompatible with the clamps we were required to use.) Oetiker is "Global", headquartered in Switzerland, manufacturing all over Europe, China, and "North America" (Canada, USA, Mexico.)
https://www.oetiker.com/en-us/produc...w-clamp-pg-178
I really like the SHIELDED Breeze clamps, especially the "Constant Torque" version with the stack of Belleville washers on the tension screw. The "Constant Torque" clamps are rather huge, and kinda unsightly. But they work VERY well, and they have the usual worm-gear clamp range of sizing. Being shielded, the hose doesn't cold-flow through the clamp.
https://www.breezehoseclamps.com/bre...nstant-torque/
Unshielded worm-gear clamps are an abomination in any size. Smaller sizes, like fuel hoses, can be clamped with inexpensive "fuel injection" clamps in 1/4", 5/16, and 3/8 sizes. I get mine from Summit.
ID:	640430   Click image for larger version
ID:	640431   Click image for larger version
Old 09-24-2024, 12:54 AM
242177P's Avatar
242177P 242177P is offline
The weight test was surprising.
Cars article. 1966 Hemi Satellite. Set a
record at Bonneville. Special clamps.
Name:	special clamps.jpg
Old 09-24-2024, 12:56 AM
Oh, yeah. There's a company selling "form-it-yourself" tools using form-to-fit stainless steel "safety wire". My concern is that the wire will eventually cut/damage the hose it's wrapped around. I'm including this because it's novel, clever, and universal, not because I actually approve. (I have not used this system.)
If it actually works without hose damage, the "clamp" would be very inexpensive, but also non-reusable and time-consuming to install.
https://clamptitetools.com/
Old 09-24-2024, 05:15 AM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Works great but not easy to do in tight spaces.
Old 09-24-2024, 10:23 AM
Looks like safety wire.
Dr. Thomas Sowell
Old 09-24-2024, 11:30 AM
I just redid EFI on a car and those shielded clamps were the best! As well as using Earls "smooth" barb fittings. The normal barbs FAST supplied the previous owner with that kit were sharp and cutting into the hose.
Old 09-24-2024, 12:01 PM
Quantum Fuel Systems use PEX type clamps on high psi fuel lines, and they do make them in larger sizes for say like rad hoses. But they don't have a wide range of clamping size so you have to buy them to close-fit before tightening. They are the Oetiker type.
https://www.highflowfuel.com/catalog...y/hose-clamps/
If you don't have to R&R the hose often, you can use the Gates PowerGrip shrink ones, but they are 1 use. They are always tight, they tighten in use to some degree. But you may initially have a little seepage. I use them on rad hoses.
https://www.gates.com/us/en/fluid-po...00-000000.html
I at one time found some good worm clamps online, they made them in black, but can't find where I got them at the moment.
I have a bunch of Gates worm clamps, as I break clamps or if the ones I have start looking crappy I swap them.
Old 09-24-2024, 07:19 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Try a local business that sells hydraulic hoses and or industrial belts
They should have some good quality stuff.
Old 09-24-2024, 10:06 PM
77 TRASHCAN's Avatar
Shut it off
Shut it off
Old 09-24-2024, 10:09 PM
Shut it off
Shut it off
