Old 08-21-2013, 02:36 PM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
Default oil pressure sensor location
My GTO came with the oil pressure line located here:
The gauge seems to dance between 80 and 100 PSI (gauge could be broken).
I've got a mechanical autometer oil pressure I want to use (instead of the current one) with a copper line instead of the plastic one and was just wondering if that's a good location.
thanks,
1968 - Pontiac GTO
Old 08-21-2013, 02:53 PM
zoso zoso is offline
there is a plug next to the distributor...that is the best most accurate location.
I have a guage running from both sites. seems the factory location at the oil filter sending unit reads a little higher than the hole next to dist...about 10 psi or so.
David Jones's Avatar
Mine picks up to the drivers side of the distributor hole in the block.
Old 08-21-2013, 03:01 PM
66bonne's Avatar
66bonne 66bonne is offline
Have mine up by the distributor also.
Jim
Old 08-21-2013, 03:08 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
On the filter housing is before the oil filter. Next to the dist is after the filter.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 08-21-2013, 04:44 PM
george kujanski's Avatar
Anyone have a pic of the dist location handy? I would like to have a sender for my gauge, and a low oil pres. switch for a light/elec. choke.
George
Old 08-21-2013, 05:14 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default gauge
I put the mechanical oil pressure connection at the dist hole. reads a few pounds lower than at oil
filter at warm idle.(had 17 at dist. location and 20 at oil filter when a swapped them).
- Use ONLY copper type line for a mechanical gauge!!!!!!
For piece of mind I put the factory type idiot light sender back in oil filter housing with stock
wiring. Car has idiot lights and like all them functional as well.
Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 08-21-2013, 06:32 PM
Chris65LeMans's Avatar
That's where mine is, and it seems to work well. More importantly - what's with the Chevy Orange motor?
Old 08-21-2013, 09:07 PM
WDCreech's Avatar
WDCreech WDCreech is offline
George
The plug in front of the date code. The square socket to remove it is 5/16".
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
Old 08-21-2013, 10:01 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I've encountered quite a few of those engines, one very recently. I've never actually talked to someone who painted it that way to find out what their logic in thinking was... Amusingly enough all have been Pontiac 350s.
Old 08-22-2013, 02:34 AM
Got it that way.. painting the engine is on my list, there's just too much other things to complete first..
and thanks for the replies everyone, learned another thing about Pontiac engines today
1968 - Pontiac GTO
Old 08-22-2013, 03:43 AM
I know what you mean, there. My car actually came with the wrong oil filter mount. (It's not angled, so the instructions for changing the oil filter include "dent the filter with a hammer so it clears the frame.") I've got the correct part, but haven't got around to it yet.
Old 08-22-2013, 03:48 AM
hmm.. at least some previous owner didn't dent the frame to clear the oil filter..
1968 - Pontiac GTO
Old 08-22-2013, 11:58 AM
That square drive factory plug may be tight. I thought a gun had gone off when mine finally broke loose.
Old 08-22-2013, 01:01 PM
Thanks, Bill, I've got it now.
George
Old 08-22-2013, 06:30 PM
chrisp chrisp is offline
That is Pontiac Carousel red . LOL
Old 08-23-2013, 09:06 AM
A.W.Dille A.W.Dille is offline
I run off the filter adaptor on my GTO and off the block on my Grand Prix. Both have done fine but I prefer coming off of the top of the block, very accurate readings.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 10-19-2024, 09:49 AM
Pgsharpp Pgsharpp is offline
I have a question does anyone have a photo of the delivery location available? I want a gauge sender and an oil pressure switch for the light/electric choke. Pgsharp
Old 10-19-2024, 10:17 AM
What do you mean by “ delivery location”?
On the factory filter adapter the 1/8” pipe threaded hole where the idiot switch goes into is right off the pump output.
The hole that’s plugged off on the top of the block on the drivers side as in these previous photos here is on the output side of the oil filter.
Old 10-19-2024, 10:44 AM
grivera's Avatar
grivera grivera is offline
If it’s the original square drive plug do not attempt to remove without soaking it with thread penetrant first and heating up - it is very easy to strip the square drive.
Will Rivera
