Old 12-25-2024, 11:53 AM
grivera's Avatar
grivera grivera is offline
Default Merry Christmas- Summit Racing 10% Off Coupons
I have 12 Summit Racing coupons for the PY family Christmas stockings! These are specifically numbered for single use. So if you decide to use one, please reply which number you used so another member doesn’t try to use the same number. Shared with the honor system in mind so please do not sell the codes on eBay. Also, in the Christmas spirit please only use one so others may have an opportunity to save some money. These expire on 12/31/24
ID:	645200   Click image for larger version
ID:	645201   Click image for larger version
ID:	645202   Click image for larger version
ID:	645203   Click image for larger version
Will Rivera
The Following 4 Users Say Thank You to grivera For This Useful Post:
Old 12-25-2024, 11:54 AM
grivera's Avatar
Two more:
Will Rivera
The Following User Says Thank You to grivera For This Useful Post:
Old 12-25-2024, 02:35 PM
VCho455's Avatar
VCho455 VCho455 is offline
Oh, you're 10 days too late or I jumped the gun 10 days ago! Would have saved a hundred bucks.
Old 12-25-2024, 04:03 PM
grivera's Avatar
Story of my life! Hopefully it will help others looking to buy some off season goodies.
Will Rivera
Old 12-26-2024, 05:18 AM
chuckies76ta's Avatar
Thank you very much for posting codes. I used Code # ZD07668814. Saved me $46.77. Thank you again. Charles
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 12-26-2024, 08:20 AM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
You’re awesome, I’m in need of an Ididit steering column and u joints, these coupons will definitely help. Merry Christmas.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
The Following User Says Thank You to *67firebird* For This Useful Post:
Old 12-26-2024, 10:42 AM
Jay S's Avatar
Jay S Jay S is offline
Thank You! I used one from post 2, ending in 8810. That was quite a stocking stuffer surprise. $187 savings! Merry Christmas and Happy New Year!
Old 12-26-2024, 02:06 PM
just saved $72 just ordered Ididit Steering column and universal shaft kit. Thanks!
I used ZD01662821
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 12-26-2024, 04:29 PM
RocktimusPryme's Avatar
Thank you. Saved some money to put decent mufflers on my 62. I used ZD07662829 which was the first of the two extra ones you posted.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 12-30-2024, 12:06 AM
cdrookie cdrookie is offline
I just used ZD09662825. Thanks grivera
The Following User Says Thank You to cdrookie For This Useful Post:
Old 12-31-2024, 11:11 AM
grivera's Avatar
Very happy these are being put to good use- they expire today at midnight so please feel free to use another if you need to - don’t feel restricted to just one per person! Will
Will Rivera
Old 12-31-2024, 01:25 PM
I tried to go through and use one more but unless I’m bad at typing it looks like they were all used. Just to save someone else some time trying them all.
Thank again.
Old 12-31-2024, 01:27 PM
grivera's Avatar
Maybe others have used them and haven’t posted ?
Will Rivera
Old 12-31-2024, 01:33 PM
Most likely yes. It’s always possible I was doing something wrong but I got the one to work the other day. Someone else can check me but I think I went through all of them.
Old 12-31-2024, 01:37 PM
grivera's Avatar
Here’s one more- thought I would use it but ain’t gonna happen! In case there’s been an entry error with the ones not accounted for, it’s worth placing the order on the phone so the rep can assist. In some cases they will give you a courtesy 10% off if the issue can’t be resolved.
Will Rivera
Old 12-31-2024, 03:02 PM
67Lemons 67Lemons is offline
I’ll take it, thank you!
The Following User Says Thank You to 67Lemons For This Useful Post:
